[Node 013] is unknown - discarding received command
So I think I deleted a node from JS UI and the device is still trying to send commands to my z-wave controller. I believe all my devices are accounted for so i have no clue what this device is… Is there any way to look in a log somewhere else to see some kind of information on this device? I have turned the onscreen log to silly and still I only get the “[Node 013] is unknown - discarding received command…”
I think I figured it out… I had to turn on logging for Z-wave to silly not the general logging.
fond this
2025-03-17T20:21:56.009Z CNTRLR   [Node 013] is unknown - discarding received command...
2025-03-17T20:21:56.011Z DRIVER « [Node 013] [REQ] [BridgeApplicationCommand]                        [discarded]
                                  │ RSSI: -79 dBm
                                  └─[BatteryCCReport]
                                      level:  100
                                      is low: false
2025-03-17T20:21:56.246Z CNTRLR   [Node 013] is unknown - discarding received command...
2025-03-17T20:21:56.250Z DRIVER « [Node 013] [REQ] [BridgeApplicationCommand]                        [discarded]
                                  │ RSSI: -79 dBm
                                  └─[MultilevelSensorCCReport]
                                      sensor type: Air temperature
                                      scale:       Fahrenheit
                                      value:       66
2025-03-17T20:21:56.506Z CNTRLR   [Node 013] is unknown - discarding received command...
2025-03-17T20:21:56.508Z DRIVER « [Node 013] [REQ] [BridgeApplicationCommand]                        [discarded]
                                  │ RSSI: -79 dBm
                                      sensor type: Humidity
                                      scale:       Percentage value
                                      value:       43
2025-03-17T20:21:56.828Z CNTRLR   [Node 013] is unknown - discarding received command...
2025-03-17T20:21:56.830Z DRIVER « [Node 013] [REQ] [BridgeApplicationCommand]                        [discarded]
                                  │ RSSI: -78 dBm
                                      sensor type: Illuminance
                                      scale:       Lux
                                      value:       91
This really narrows it down to two devices!!
