I added a new node to my installation, and although I can upload the code (flashing and OTA), the entities are not available
Here’s the code for the node:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
networks:
- ssid: "soldanet"
password: "PASSW"
priority: 10.0
- ssid: "soldanet2"
password: "PASSW"
priority: 20.0
ap:
ssid: "Alacena Fallback Hotspot"
password: "PASSW"
captive_portal:
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
ota:
- platform: dht
pin: 0
model: DHT11
temperature:
accuracy_decimals: 1
#filters:
#- offset: -0.5
humidity:
filters:
- median:
window_size: 5
send_every: 4
send_first_at: 3
switch:
- platform: gpio
pin: 2
on_turn_on:
- delay: 500ms
- switch.turn_off: rele_alacena
And the logs:
INFO Reading configuration /config/esphome/alacena1.yaml...
INFO Starting log output from alacena1.local using esphome API
INFO Connecting to alacena1.local:6053 (192.168.1.247)
INFO Successfully connected to alacena1.local
[13:54:12][I][app:105]: ESPHome version 1.18.0 compiled on May 28 2021, 11:42:42
[13:54:12][C][wifi:443]: WiFi:
[13:54:12][C][wifi:303]: SSID: [redacted]
[13:54:12][C][wifi:304]: IP Address: 192.168.1.247
[13:54:12][C][wifi:306]: BSSID: [redacted]
[13:54:12][C][wifi:307]: Hostname: 'alacena1'
[13:54:12][C][wifi:311]: Signal strength: -73 dB ▂▄▆█
[13:54:12][V][wifi:313]: Priority: 20.0
[13:54:12][C][wifi:315]: Channel: 10
[13:54:12][C][wifi:316]: Subnet: 255.255.255.0
[13:54:12][C][wifi:317]: Gateway: 192.168.1.1
[13:54:12][C][wifi:318]: DNS1: 192.168.1.10
[13:54:12][C][wifi:319]: DNS2: 1.1.1.1
[13:54:12][C][switch.gpio:042]: GPIO Switch 'Extractor alacena'
[13:54:12][C][switch.gpio:043]: Pin: GPIO2 (Mode: OUTPUT)
[13:54:12][C][switch.gpio:059]: Restore Mode: Restore (Defaults to OFF)
[13:54:12][C][logger:189]: Logger:
[13:54:12][C][logger:190]: Level: VERBOSE
[13:54:12][C][logger:191]: Log Baud Rate: 115200
[13:54:12][C][logger:192]: Hardware UART: UART0
[13:54:12][C][dht:017]: DHT:
[13:54:12][C][dht:018]: Pin: GPIO0 (Mode: INPUT)
[13:54:12][C][dht:022]: Model: DHT11
[13:54:12][C][dht:027]: Update Interval: 60.0s
[13:54:12][C][dht:029]: Temperature 'Temperatura alacena'
[13:54:12][C][dht:029]: Device Class: 'temperature'
[13:54:12][C][dht:029]: Unit of Measurement: '°C'
[13:54:12][C][dht:029]: Accuracy Decimals: 1
[13:54:12][C][dht:030]: Humidity 'Humedad alacena'
[13:54:12][C][dht:030]: Device Class: 'humidity'
[13:54:12][C][dht:030]: Unit of Measurement: '%'
[13:54:12][C][dht:030]: Accuracy Decimals: 0
[13:54:12][C][captive_portal:169]: Captive Portal:
[13:54:12][C][ota:029]: Over-The-Air Updates:
[13:54:12][C][ota:030]: Address: alacena1.local:8266
[13:54:12][C][api:095]: API Server:
[13:54:12][C][api:096]: Address: alacena1.local:6053
[13:54:21][W][dht:162]: Requesting data from DHT failed!
[13:54:21][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
[13:54:21][V][sensor:013]: 'Temperatura alacena': Received new state nan
[13:54:21][D][sensor:099]: 'Temperatura alacena': Sending state nan °C with 1 decimals of accuracy
[13:54:21][V][sensor:013]: 'Humedad alacena': Received new state nan
As you might notice, the DHT11 sensor is not even sending the readings.
This is the schematic for the board:
Any idea or suggestion will be greatly appreciated.
