Node.js library to create Telegram bots for Home Assistant easily
I created a small Node.js library (mainly for myself) to create Telegram bots for Home Assistant with very little and clean code.
A simple bot looks like this:
var Bot = require('home-assistant-telegram-bot').Bot
var bot = new Bot({
    token: '<Telegram bot token>',
    url: '<Home Assistant url>',
bot.on('/temp', function(chat, hass) {
    chat.send(' Temp: {{sensor.temperature.state}} °C ')
bot.on('/light', function(chat, hass) {
    hass.switch.light1.toggle()
    chat.send('Ok')
bot.observeState('sensor.wind', function(state, hass) {
    if (state > 10) {
        bot.sendToAll('It`s windy!')
As you can see, it can do three things:
  • Send values from Home Assistant sensors
  • Control HomeAssistant devices
  • Observe a state and inform the user when it changes
The library is available on Github and via npm.
Maybe it’s useful to someone.
Looks to be very useful. thanks for sharing :slight_smile:
