In my Hass.io add-on detail I see there is an update available for Node-RED. I’m currently running 2.0.2 and the update is for 3.0.3. The system won’t let me update because it says “This update is no longer compatible with your system”.
Is this true?
Yes the version 3.0.0 (the next one after 2.0.2) adds Hass.io Ingress support. Then you shall update HA to 0.92.x to use it.
Thanks @Adorem, updating to 0.92 solved the issue!
