Node-RED Addon Where to delete Home Assistant Instances
I have put in the incorrect server details for one of my Home Assistant instances and now my Node-RED is stuck in an infinite loop. Where can I find the details for the configured Home Assistant Instances it listens to so I can remove the error in configuration.
OK so any mistakes can be found in the flows.json with the node-red folder you can just remove the "type:“server” line and restart and all will be good in NR world again :+1:
