I have just started to run node red and fails with my sequencies. I’m starting with turning lights on and off.
In my node red log I have rows like this:
8 Feb 21:55:55 - [error] [api-call-service:Tänd i fönstret] Call-Service attempted without connection to server.
8 Feb 21:55:55 - [error] [api-call-service:Tänd i hall] Call-Service attempted without connection to server.
8 Feb 21:55:57 - [info] [server:Home Assistant] Connecting to http://supervisor/core
8 Feb 21:55:57 - [info] [server:Home Assistant] Connected to http://supervisor/core
It looks like node red calls servicies in HA before there is a connection.
When I edit the nodes in my sequencies I get help with getting completion help when editing servicies or entities so at this time there is a connection.
My node red config looks like this:
credential_secret: <secret>
dark_mode: false
http_node:
username: ''
password: ''
http_static:
username: ''
password: ''
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
require_ssl: false
system_packages: []
npm_packages: []
init_commands: []
I only edit the credentials and set the ssl options to false.
My understanding was that I should configure as little as possible.
I apparently miss something. Anyone who knows what?
Running HA core-2021.2.1 and node red 8.1.1
