Node-red-dashboard 2.22.1 update and 1880 port error
Hello and thank you for welcoming me to this community.
I really like using Node-Red and I’m learning how to use the dashboard as well. Node-Red run on Raspberry Pi 3+ in Hassio Home Assistant. As the subject says, after update Node-red-dashboard 2.22.1, when I load the Dashboard:
3_NR
That is, it uses port 8123 instead of 1880
However, by manually changing the port to 1880 in the browser, I can display my dashboard correctly.
Thank you all and consider that I am a noob, so apologize in advance for my questions…
Ciao, Max
Max, this section is for the HADashboard which is a part of Appdaemon. Try posting your question in the Node-RED section instead.
Whooops!!! Sorry.
Thank you Tomas, my mistske.
Max.
