Node-red dashboard hosed
I was playing with the added pallets and selected a node-red_contrib_ui_j which hosed my dashboard.
I can not seem to uninstall it, reinstall the normal dashboard, etc. I have tried to uninstall through the interface, I tried it from the command line, I dried uninstalling node-red and reinstalling it but it is still there. Heck, I even tried removing the docker container and forcing it to download a new one. and it is still there.
How can I remove this or reset node-red to original install defaults short of reinstalling my entire HA server?
It’s a test system and there is only a couple of test flows so recreating the flows is no big deal.
If you’re using my addon, delete /share/node-red then start the addon.
As a matter of fact, I am using your addon and that did the trick!
Thank you very much!
