Node Red Error: npm ERR! Cannot convert undefined or null to object
rebooted my instance for the first time in a while and seemingly it wont come back up
enabled debug logs and see the following:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 11.1.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 8.1  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2022.6.2
 Home Assistant Supervisor: 2022.05.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to DEBUG
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 succeeded at 1164 (offset 633 lines).
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2022-06-06T01_14_55_254Z-debug.log
[21:14:55] FATAL: Failed un-installing conflicting packages
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
ive tried googling.
ive tried reinstall of the addon
ive tried reboot of the HA isntance
tried setting some npm packages based on some other threads
so far nothing has helped.
Any help is appreciated
Found a fix here:
