[node-red] flow that wait for two different state changes
I’m trying to make a flow that behave like this:
Alarm goes from state A to state B (only) → the flow wait for like 10sec and then if the door open start the flow, if not return the the first step and wait for the next time the alarm goes from A to B. For the first part, as suggested in another Topic, I’m using a Trigger node with 2 conditions but I cannot find a way to make the flow in “wait for X seconds” before turning back.
Surely is something that could be done, but I need the help of more knowlageble people than me.
Thanks in advance,
Show a screenshot of what you have now.
Look at the stoptimer-varidelay node. It is quite flexible, but the documentation looks like it was written by an engineer.
stoptimer-varidelay
General usage
Sends the msg through the first output after the set timer duration. If a new msg is received before the timer has ended, it will replace the existing msg and the timer will be restarted, unless the new msg has a payload of stop or STOP, in which case it will stop the timer. The second output allows you to send an additional payload of a number, string or boolean. If the timer is stopped, the second and third output will automatically send a payload of stopped. The third output will send the time remaining as time ticks away.
The status below the node as well as the third output can be configured via the Reporting field in the node to update a frequency of:
Never(default)
Every Second
Every Minute, Last minute by seconds
The last option works as follows:
While there is more than 1 minute remaining, the timer will decrement every minute. At the 1 minute point, it will switch to reporting every second.
The exception to this rule is if your duration is not a minute increment. In that case, the first update will be for the partial minute, after which it will operate as noted above. (for example: 2.5 minutes will decrement to 2 minutes, then 1 minute, then every second down to zero)
The format of the reporting (and status) are defined by the "Reporting Format" option. The default is hh:mm:ss (string), but it can be configured to present that as the total number of seconds, minutes or hours (number) instead.
Overriding the node via incoming messages
If the input contains msg.delay, then the delay will be msg.delay units of time, where the units are whatever the units are defaulted to in the node iteself. In the absense of a msg.delay, or a value in msg.delay that can not be converted to an int, the value configured within the node will be used. If the value of msg.delay is less than 0, then 0 is used.
If the input contains msg.units, with a value of "Milliseconds", "Seconds", "Minutes" or "Hours" then that will over-ride what is defaulted in the node. In the absense of a msg.units, or an unknown string in msg.units the units configured within the node will be used. In the case of an unknown string, a warning message will appear in the Debug logs.
Special Note on Milliseconds While you can set Milliseconds, I would not rely on the accuracy for anything critical. For the purposes of the node status and output 3, except in the case where Reporting is set to None, the milliseconds are not displayed or provided on the 3rd output as it wouldn't make sense based on the available reporting rates.
Resume timer on deploy/restart This option is DISABLED by default. If you ENABLE it (check the checkbox) then if the stoptimer is running and you re-Deploy the flow, or restart Node-RED, then the timer will automatically restart itself where it should be. What does that mean? A couple of examples will help here.
If you had a 10 minute stoptimer running, with 6 minutes elapsed (ie: 4 minutes left) and you hit Deploy, normally the stoptimer would no longer be running, but if you have this feature enabled, the timer will continue running from the 6 minute mark (ie: counting down 4 more minutes and then trigger).
If you had a 10 minute stoptimer running, with 6 minutes elapsed (ie: 4 minutes left) and you stopped Node-RED for 2 minutes and then restarted it, normally the stoptimer would no longer be running, but if you have this feature enabled, the timer will continue running from the 8 minute mark (6 minutes from the original run + 2 minutes of Node-RED downtime) -- counting down 2 more minutes and then trigger.
Special Case If on restart or re-Deploy, there is less than 3 seconds remaining on the stoptimer (or if the stoptimer should have elapsed already) then the stoptimer is set to a random amount between 3 and 8 seconds. This helps to ensure than anything else that needs to initialize before the stoptimer triggers, has a chance to initialize, it also helps so that if you happen to have a lot of timers, they don't all trigger at once and flood unsuspecting nodes/devices.
This persistence is not related to "Persistent Context" (the contextStorage option in settings.js). When the "Resume timer" option is enabled in the node, the node will store timer related information in a stvd-timers subdirectory of userDir (where userDir is defined in settings.js). If userDir is not explicitly defined, it defaults to a directory called .node-red in your home user directory. The files in this directory will be created/destroyed as needed by the node.
What is _timerpass _timerpass is a property added to messages exiting the 1st/top and 2nd/middle outputs of stoptimer. _timerpass is set to true when the timer expires.
What does _timerpass do? If stoptimer has at any point been stopped using message.payload=stop (or STOP) AND
If stoptimer has not received a message with _timerpass not set since that time THEN
any incoming message that has the _timerpass=true property will die within stoptimer with no output.
This can be problematic if you want to chain multiple stoptimers together. It is not insurmountable, but it can be irritating. Why does this behavior exist? It is a legacy thing, it was part of the original stoptimer whose code I forked. Not sure what exactly the original intent was, but I'm sure there is some rationale. How does Stoptimer-Varidelay handle this? Ignore Timerpass in the node config dialog. If enabled in a given stoptimer-varidelay node, it will ignore the presence of the _timerpass property on an incoming message and will process the incoming message as it does every other message. By default, this option is not enabled in order to preserve compatibility with any existing flows. Note that you may need to refresh the web ui after updating the node in order to see the new "ignore timerpass" option.
[{"id":"056cebf8b8ea913a","type":"ha-wait-until","z":"8e6ef4f6cbb13d83","name":"","server":"","version":3,"outputs":2,"entities":{"entity":[],"substring":[],"regex":[]},"property":"","comparator":"is","value":"on","valueType":"str","timeout":"10","timeoutType":"num","timeoutUnits":"seconds","checkCurrentState":true,"blockInputOverrides":true,"outputProperties":[],"x":520,"y":100,"wires":[[],[]]},{"id":"f3a1aa76bfd7b325","type":"trigger-state","z":"8e6ef4f6cbb13d83","name":"from A to B","server":"","version":5,"inputs":0,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":[],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":""}],"customOutputs":[],"outputInitially":false,"stateType":"str","enableInput":false,"x":340,"y":100,"wires":[["056cebf8b8ea913a"],[]]}]
Seems the right idea, thanks a lot.
