Node red for two conditions
I want to use a sensor to measure pressure and time in the red node. Use these two conditions to make the device work.
What should I use and how to set it up?
First I think you should be more clear in what you want? You want to measure time of what? What device should “work”? What does that mean, do you mean the device has to start doing something?
