Node red, Govee node
Can someone verify that the node red Govee node works on node red in home assistant?
I have tried 2 different installs and can’t get it to install.
I use it on a non home assistant node red install on raspi3 and that works great.
Thanks in advance.
The first govee node I found had dependencies, did you install them first?
I’m not sure
Do you remember what those are?
I don’t, just google the name of the node you are using and read the directions.
