Node-red, Hassio & Xiaomi motion sensor
Saw other people having a lot of success with Node-red on Hassio online and decided to give it a go.
Was able to follow the example at DIY Futurism (https://diyfuturism.com/index.php/2017/11/26/the-open-source-smart-home-getting-started-with-home-assistant-node-red/) and that’s about it.
I’m trying to set up a flow to do the following:
Xiaomi Motion sensor - motion detected
Turns on Light for 30 seconds
If after midnight and before sunset, lights on at 10%
Completely stumped by this - any help would be gratefully appreciated!
Take look at this. The first one turns on the toilet light only after certain dark hours using the xiaomi motion sensor at full brightness until 21:00, after that it goes to minimum brightness, and warm light until end of night.
The second one takes care of turning off the light, in case someone forgets to turn it off the light via the xiaomi wall switch.
Don’t forget to change your ha url and password.
Hope it helps
[{"id":"761b8f45.ef05d","type":"server-state-changed","z":"d6bc1d0b.a1a34","name":"ToiletMotionSensor","server":"d5ce5cec.92bc8","entityidfilter":"binary_sensor.motion_sensor_158d0001e55241","entityidfiltertype":"substring","haltifstate":"off","x":130,"y":260,"wires":[["15469816.653ff8"]]},{"id":"e8cd416a.5f2f6","type":"api-call-service","z":"d6bc1d0b.a1a34","name":"LateNight","server":"d5ce5cec.92bc8","service_domain":"light","service":"turn_on","data":"{ \"entity_id\":\"light.bathroom\", \"brightness\": 2,\"rgb_color\": [255, 120, 0]}","mergecontext":"","x":1260,"y":300,"wires":[[]]},{"id":"10038ad8.9bfd35","type":"time-range-switch","z":"d6bc1d0b.a1a34","name":"LateOrEarlyNight","lat":"-26.7880988","lon":"153.1214329","startTime":"sunset","endTime":"21:00","startOffset":"-45","endOffset":"","x":1050,"y":260,"wires":[["eeb4eeb4.8a10c"],["e8cd416a.5f2f6"]]},{"id":"eeb4eeb4.8a10c","type":"api-call-service","z":"d6bc1d0b.a1a34","name":"EarlyNight","server":"d5ce5cec.92bc8","service_domain":"light","service":"turn_on","data":"{ \"entity_id\":\"light.bathroom\", \"brightness\": 255, \"rgb_color\": [255,236,221]}","mergecontext":"","x":1270,"y":220,"wires":[[]]},{"id":"15469816.653ff8","type":"time-range-switch","z":"d6bc1d0b.a1a34","name":"CheckTime","lat":"-26.7880988","lon":"153.1214329","startTime":"sunrise","endTime":"sunset","startOffset":"30","endOffset":"-45","x":670,"y":260,"wires":[[],["10038ad8.9bfd35"]]},{"id":"f4a97312.ebd6b","type":"comment","z":"d6bc1d0b.a1a34","name":"Turn on toilet light at night","info":"","x":200,"y":200,"wires":[]},{"id":"8db0789c.0e1788","type":"comment","z":"d6bc1d0b.a1a34","name":"Turn off toilet light ","info":"","x":190,"y":500,"wires":[]},{"id":"38c1ff40.d18bc","type":"server-state-changed","z":"d6bc1d0b.a1a34","name":"ToiletLight","server":"d5ce5cec.92bc8","entityidfilter":"light.bathroom","entityidfiltertype":"substring","haltifstate":"","x":180,"y":580,"wires":[["76e1bc21.87ea14"]]},{"id":"76e1bc21.87ea14","type":"switch","z":"d6bc1d0b.a1a34","name":"LightOn","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":360,"y":580,"wires":[["6e47b359.1532ec"]]},{"id":"6e47b359.1532ec","type":"delay","z":"d6bc1d0b.a1a34","name":"5Minutes","pauseType":"delay","timeout":"5","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":500,"y":580,"wires":[["d1c1080a.440d78"]]},{"id":"d1c1080a.440d78","type":"api-current-state","z":"d6bc1d0b.a1a34","name":"CheckSensor","server":"d5ce5cec.92bc8","halt_if":"","override_topic":true,"override_payload":true,"entity_id":"binary_sensor.motion_sensor_158d0001e55241","x":720,"y":720,"wires":[["1719bd4f.d48593"]]},{"id":"1719bd4f.d48593","type":"switch","z":"d6bc1d0b.a1a34","name":"checkForDelay","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":760,"y":580,"wires":[["db4e432c.f803c"],[]]},{"id":"db4e432c.f803c","type":"delay","z":"d6bc1d0b.a1a34","name":"3Minutes","pauseType":"delay","timeout":"3","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1000,"y":500,"wires":[["a3a0a7c5.74a248"]]},{"id":"a3a0a7c5.74a248","type":"api-current-state","z":"d6bc1d0b.a1a34","name":"CheckSensor","server":"d5ce5cec.92bc8","halt_if":"","override_topic":true,"override_payload":true,"entity_id":"binary_sensor.motion_sensor_158d0001e55241","x":1200,"y":500,"wires":[["ef3ff256.8ba43"]]},{"id":"ef3ff256.8ba43","type":"switch","z":"d6bc1d0b.a1a34","name":"presenceDetected","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1390,"y":500,"wires":[["24d665bd.8a183a"],["6f90347b.24537c"]]},{"id":"24d665bd.8a183a","type":"api-call-service","z":"d6bc1d0b.a1a34","name":"TurnOff","server":"d5ce5cec.92bc8","service_domain":"light","service":"turn_off","data":"{ \"entity_id\":\"light.bathroom\"}","mergecontext":"","x":1580,"y":460,"wires":[["502efc34.9f81b4"]]},{"id":"502efc34.9f81b4","type":"debug","z":"d6bc1d0b.a1a34","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1510,"y":820,"wires":[]},{"id":"6f90347b.24537c","type":"delay","z":"d6bc1d0b.a1a34","name":"30Seconds","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1230,"y":640,"wires":[["a3a0a7c5.74a248"]]},{"id":"d5ce5cec.92bc8","type":"server","z":"","name":"Home Assistant","url":"https://HA:8123","pass":"password"}]
