Hi guys,
Almost have my human recognition alarm system fully working in node-red except for a small detail related to a payload I need to pass across 2 different nodes .
Here is a screenshot of my flow (added the red arrow just to make it clear where the Convert payload should be sent to and where I added the alarm state conditions) :
"id": "1f106aac.627ac5",
"type": "change",
"z": "5bee2e87.e0fc5",
"name": "Convert",
"rules": [
"t": "delete",
"p": "payload",
"pt": "msg"
"t": "set",
"p": "data.base_id",
"pt": "msg",
"to": "$match(topic, /binary_sensor.(\\w{3})/).groups[0].$string()",
"tot": "jsonata"
"t": "set",
"p": "data.camera",
"pt": "msg",
"to": "\"camera.\" & $.data.base_id",
"tot": "jsonata"
"t": "set",
"p": "data.image_processing",
"pt": "msg",
"to": "\"image_processing.rekognition_person_\" & $.data.base_id",
"tot": "jsonata"
"t": "set",
"p": "data.camera_snapshot",
"pt": "msg",
"to": "\"https://hassio.duckdns.org/local/camera_snapshot/snapshot_\" & $.data.base_id & \".jpg\"",
"tot": "jsonata"
"t": "set",
"p": "payload.entity_id",
"pt": "msg",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 300,
"y": 340,
"wires": [
"59df5b16.db7964",
"22f6ac5c.e83384",
"fe673483.603ed8"
"id": "59df5b16.db7964",
"type": "template",
"name": "Set Snapshot",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "{\n\t\"data\": {\n\t\t\"entity_id\": \"{{data.camera}}\",\n\t\t\"filename\": \"/config/www/camera_snapshot/snapshot_{{data.base_id}}.jpg\"\n\t}\n}",
"output": "json",
"x": 620,
"y": 400,
"wires": [
"e6176341.cacbb"
"id": "e6176341.cacbb",
"type": "api-call-service",
"name": "Snapshot",
"server": "e94c8527.3f2d08",
"version": 1,
"debugenabled": false,
"service_domain": "camera",
"service": "snapshot",
"entityId": "{{data.camera}}",
"data": "{\"filename\":\"{{data.camera_snapshot}}\"}",
"dataType": "json",
"mergecontext": "",
"output_location": "",
"output_location_type": "none",
"mustacheAltTags": false,
"x": 900,
"y": 400,
"wires": [
"id": "fe673483.603ed8",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 420,
"y": 520,
"wires": [
"c5666c97.b2e0b"
"id": "c5666c97.b2e0b",
"name": "Rekognition",
"version": 1,
"debugenabled": true,
"service_domain": "image_processing",
"service": "scan",
"entityId": "",
"data": "{\"entity_id\":\"{{data.image_processing}}\"}",
"dataType": "json",
"mergecontext": "",
"x": 590,
"y": 520,
"wires": [
"ca5283b3.37de5"
"id": "ca5283b3.37de5",
"type": "api-current-state",
"name": "Person Check",
"version": 1,
"outputs": 2,
"halt_if": "0",
"halt_if_type": "num",
"halt_if_compare": "gt",
"override_topic": false,
"entity_id": "",
"state_type": "num",
"state_location": "",
"override_payload": "none",
"entity_location": "aws_data",
"override_data": "msg",
"blockInputOverrides": false,
"x": 900,
"y": 500,
"wires": [
"4e9b5265.4a9c2c"
"id": "22f6ac5c.e83384",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"x": 570,
"y": 320,
"wires": []
"id": "fdb92e2a.3d32",
"type": "catch",
"name": "",
"scope": null,
"uncaught": false,
"x": 640,
"y": 460,
"wires": [
"ca5283b3.37de5"
"id": "cdd5f4b8.f59c68",
"type": "server-state-changed",
"name": "Camera Motion",
"version": 1,
"entityidfilter": "binary_sensor.\\w{3}",
"entityidfiltertype": "regex",
"outputinitially": true,
"state_type": "str",
"haltifstate": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": false,
"x": 100,
"y": 340,
"wires": [
"1f106aac.627ac5"
"id": "a3999516.0c89f8",
"type": "switch",
"name": "Filter Alarm Status",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "armed_home",
"vt": "str"
"t": "eq",
"v": "armed_away",
"vt": "str"
"t": "eq",
"v": "disarmed",
"vt": "str"
"t": "eq",
"v": "triggered",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 4,
"x": 430,
"y": 220,
"wires": [
"id": "4c399fa.3b3036",
"name": "alarmstate",
"version": 1,
"outputs": 1,
"halt_if": "",
"entity_id": "alarm_control_panel.home_alarm",
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"x": 210,
"y": 220,
"wires": [
"a3999516.0c89f8"
"id": "e94c8527.3f2d08",
"type": "server",
"z": "",
"name": "Home Assistant"
I need to add the condition of halting the flow based on the state of my alarm before the Rekognition node but I am not sure how to do it without breaking the payload sent from the Convert Node .
How can I pass the multiple payloads in the Convert node while adding an halt condition in between ?
Thanks !
