I have a flow which was working, and now isn’t. I have added components to the end of it but not the start, and it’s early on it fails. The only significant change I have made is to delete cookies from my browser, but am not sure this should be affecting anything.
More details: I am calling a weather service, and it works fine from the Terminal inside HA using curl.
Same instruction with appropriate message header agent and identifier as per the instructions, and it used to work from within node red, but now hangs on ‘requesting’ and gets no further. Rebooted the Proxmox container with HA as well as HA - doing that made it work once, but not again.
Where do I look for possible causes?
URL call:
https://api.met.no/weatherapi/locationforecast/2.0/compact?altitude=0&lat=10.0&lon=0.0
(edited for privacy).
No errors in the logs (relevant to this - my old playing with Google maps needs to come out as does my bluetooth tracking, but these are independent of this issue).
2021-05-13 23:54:21 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-05-13 23:54:22 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=24 from 2021-05-13 22:30:50.766661)
2021-05-13 23:54:25 INFO (Thread-3) [roonapi] Connecting to Roon server 192.168.1.171:9100
2021-05-13 23:54:25 INFO (Dummy-7) [roonapi] Connection with roon websockets (re)created.
2021-05-13 23:54:25 INFO (Dummy-7) [roonapi] Confirming previous registration with Roon…
2021-05-13 23:54:25 INFO (Thread-5) [roonapi] Registered to Roon server ROCK
2021-05-13 23:54:26 ERROR (SyncWorker_0) [homeassistant.components.google_maps.device_tracker] The cookie file provided does not provide a valid session. Please create another one and try again
2021-05-13 23:54:26 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy google_maps
2021-05-13 23:54:26 WARNING (SyncWorker_1) [homeassistant.components.bluetooth_le_tracker.device_tracker] No Bluetooth LE devices to track!
2021-05-13 23:54:26 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy bluetooth_le_tracker
ETA: other websites are accessible from the node red system.
