Hello guys,
i was travelling in past month and everything was ok at my HA. Now, im back and my Node-RED stopped to. The issues tab says that some entities was not found. I dont know what is wrong. Someone could help me?
12 Feb 17:22:14 - [error] [api-current-state:Tomou os Remédios?] InputError: Entity could not be found in cache for entityId: input_boolean.medicado_atentah
12 Feb 17:22:14 - [error] [api-call-service:Desliga Medicado Vivian] NoConnectionError
12 Feb 17:22:14 - [error] [api-current-state:Vivian tomou os Remédios?] InputError: Entity could not be found in cache for entityId: input_boolean.vivian_medicada
12 Feb 17:22:14 - [error] [api-call-service:Desliga Medicado Reconter] NoConnectionError
12 Feb 17:22:15 - [warn] [alexa-remote-account:1d9308ddb3959360] failed to load routines: "no body"
12 Feb 17:22:17 - [error] [proxmox-server:c1a9f33ff5a65eaa] Failed to connect to Proxmox
12 Feb 17:22:17 - [error] [proxmox-server:c1a9f33ff5a65eaa] StatusCodeError: 401 - {"data":null}
Unhandled rejection ReferenceError: response is not defined
at /config/node_modules/node-red-contrib-proxmox/proxmox/proxmox-server.js:73:47
at tryCatcher (/config/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/config/node_modules/bluebird/js/release/promise.js:547:31)
at Promise._settlePromise (/config/node_modules/bluebird/js/release/promise.js:604:18)
at Promise._settlePromise0 (/config/node_modules/bluebird/js/release/promise.js:649:10)
at Promise._settlePromises (/config/node_modules/bluebird/js/release/promise.js:725:18)
at _drainQueueStep (/config/node_modules/bluebird/js/release/async.js:93:12)
at _drainQueue (/config/node_modules/bluebird/js/release/async.js:86:9)
at Async._drainQueues (/config/node_modules/bluebird/js/release/async.js:102:5)
at Immediate.Async.drainQueues (/config/node_modules/bluebird/js/release/async.js:15:14)
at processImmediate (node:internal/timers:491:21)
12 Feb 17:22:19 - [info] [server:Home Assistant] Connecting to http://supervisor/core
12 Feb 17:22:19 - [info] [server:Home Assistant] Connected to http://supervisor/core
12 Feb 17:22:32 - [error] [api-current-state:Temperatura do CPU Proxmox] InputError: Entity could not be found in cache for entityId: sensor.proxmox_cpu_temperature
12 Feb 17:22:41 - [error] [api-current-state:Temperatura do CPU Proxmox] InputError: Entity could not be found in cache for entityId: sensor.proxmox_cpu_temperature
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[17:23:00] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
12 Feb 17:23:00 - [info] Stopping flows
12 Feb 17:23:00 - [info] [server:Home Assistant] Closing connection to http://supervisor/core
12 Feb 17:23:00 - [info] Stopped flows
[17:23:01] INFO: Service Node-RED exited with code 0 (by signal 0)
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 19.0.0
You are running the latest version of this add-on.
System: Home Assistant OS 14.2 (amd64 / qemux86-64)
Home Assistant Core: 2025.2.2
Home Assistant Supervisor: 2025.02.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 318 packages in 16s
62 packages are looking for funding
run `npm fund` for details
25 vulnerabilities (5 low, 11 moderate, 9 high)
To address issues that do not require attention, run:
npm audit fix
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
[17:23:22] INFO: Starting Node-RED...
s6-rc: info: service legacy-services successfully started
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
12 Feb 17:23:24 - [info]
Welcome to Node-RED
12 Feb 17:23:24 - [info] Node-RED version: v4.0.8
12 Feb 17:23:24 - [info] Node.js version: v22.11.0
12 Feb 17:23:24 - [info] Linux 6.6.73-haos x64 LE
12 Feb 17:23:24 - [info] Loading palette nodes
12 Feb 17:23:25 - [info] Node-RED Contrib Theme Collection version: v4.0.11
12 Feb 17:23:26 - [info] node-red-contrib-telegrambot version: v16.1.2
12 Feb 17:23:28 - [info] Dashboard version 3.6.5 started at /endpoint/ui
(node:334) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
12 Feb 17:23:29 - [info] node-red-contrib-home-assistant-websocket v0.75.0 nodes initialized
12 Feb 17:23:29 - [info] Settings file : /etc/node-red/config.js
12 Feb 17:23:29 - [info] Context store : 'default' [module=memory]
12 Feb 17:23:29 - [info] User directory : /config/
12 Feb 17:23:29 - [warn] Projects disabled : editorTheme.projects.enabled=false
12 Feb 17:23:29 - [info] Flows file : /config/flows.json
12 Feb 17:23:29 - [info] Server now running at http://127.0.0.1:46836/
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
12 Feb 17:23:29 - [info] Starting flows
12 Feb 17:23:29 - [warn] [telegram bot:54e282a1aafddfe8] Aborting: Token of Octopus is not set
[17:23:29] INFO: Starting NGinx...
nginx: [warn] the "listen ... http2" directive is deprecated, use the "http2" directive instead in /etc/nginx/servers/direct.conf:3
12 Feb 17:23:29 - [error] [ha-sensor:8cde7329121d669f] Error: Invalid entity config
12 Feb 17:23:29 - [error] [ha-sensor:46bd6a6bbf637137] Error: Invalid entity config
12 Feb 17:23:29 - [error] [ha-sensor:c1651e31460ae28a] Error: Invalid entity config
12 Feb 17:23:29 - [error] [ha-sensor:d0090dd2a9541423] Error: Invalid entity config
12 Feb 17:23:29 - [error] [ha-sensor:c35bd9d3ac2a4e41] Error: Invalid entity config
12 Feb 17:23:29 - [warn] [telegrambot-notify:Avisa Telegram] bot not initialized
12 Feb 17:23:29 - [info] Started flows
12 Feb 17:23:29 - [info] [alexa-remote-account:1d9308ddb3959360] intialising with the PROXY method and saved data...
12 Feb 17:23:29 - [error] [api-call-service:Desliga Medicado Atentah] NoConnectionError
12 Feb 17:23:29 - [error] [api-current-state:Tomou os Remédios?] InputError: Entity could not be found in cache for entityId: input_boolean.medicado_atentah
12 Feb 17:23:29 - [error] [api-call-service:Desliga Medicado Vivian] NoConnectionError
