Node-RED on hass.io VM v92.2 - dashboard gives 404
Does anyone have a working dashboard under v92.2?
Mine is set to use /ui… but I cannot get it to work under ingress URL pathing… so I get a 404: Not Found error on the page.
I tried using the ingress URL and appending /ui but that didnt work either… stuck here.
Anyone?
Hello
Try this link
https://******.duckdns.org:1880/endpoint/ui/
This link has solved my problem !
