Node Red Permissions Error
NR stopped working on my RPi3 hass.io (0.72.1) this evening and the watchdog didn’t seem to reboot it - came to look in the logs and I’m getting the following error Unknown system error -117: Unknown system error -117, access '/share/node-red/node_modules/npm/node_modules/npm-audit-report.
Tried a rebuild and erasing my settings.js to no avail - don’t know if anyone’s encountered similar or could suggest a solution? My automations have ground to a halt and the wife isn’t happy that none of the Xiaomi Smart Buttons function any more!
[INFO] Creating default settings
[INFO] Enabling SSL
[INFO] Updating IDE Users
[INFO] Adding IDE User xxxxx
[INFO] Updating HTTP Node User
[INFO] Adding HTTP Node User xxxxx
[INFO] Disabling Projects
[INFO] Attempting to install/update nodes: node-red-contrib-home-assistant
npm info it worked if it ends with ok
npm info using [email protected]
npm http fetch GET 200 https://registry.npmjs.org/node-red-contrib-home-assistant 476ms
npm http fetch GET 200 https://registry.npmjs.org/protoduck 106ms
npm http fetch GET 200 https://registry.npmjs.org/genfun 74ms
npm http fetch GET 200 https://registry.npmjs.org/npm-audit-report 59ms
npm http fetch GET 200 https://registry.npmjs.org/console-control-strings 56ms
npm WARN checkPermissions Missing write access to /share/node-red/node_modules/npm/node_modules/npm-audit-report
npm WARN [email protected] No repository field.
npm WARN [email protected] No license field.
npm ERR! path /share/node-red/node_modules/npm/node_modules/npm-audit-report
npm ERR! code Unknown system error -117
npm ERR! errno -117
npm ERR! syscall access
npm ERR! Unknown system error -117: Unknown system error -117, access ‘/share/node-red/node_modules/npm/node_modules/npm-audit-report’
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2018-07-05T23_34_55_853Z-debug.log
[ERROR] Can’t install nodes!
