Hi everyone,
I am a beginner when it comes to HomeAssistant and homeautomation in general. I do have experience with coding, so I am familier with the debugging process overall.
I am running a RPi4 with HassIO installed (balenaetcher method, not docker install). During my time testing out homeassistant, I also explored docker installation of supervised homeassistant, which I installed on a virtual ubuntu machine running on my primary PC. All of this is working well, and I am planning to move forward with the RPi4 setup, because I may want to turn off my PC from time to time.
Now, on to the issue at hand. I am trying to set up a few sensors with NodeMCU and ESPHome, following this tutorial. Initially, I had some trouble getting the device recognized, but eventually, I got the deviced flashed. Then after flashing, the device never could connect to wifi, it always errors out.
[20:29:43][W][wifi_esp8266:334]: Event: Disconnected ssid='dipanwifi' reason='Probe Request Unsuccessful'
[20:29:43][W][wifi:451]: Error while connecting to network.
[20:29:43][I][wifi:193]: WiFi Connecting to 'dipanwifi'...
[20:29:53][W][wifi_esp8266:337]: Event: Disconnected ssid='dipanwifi' bssid=[redacted] reason='4-Way Handshake Timeout'
[20:29:53][W][wifi:451]: Error while connecting to network.
OR
[20:15:23][W][wifi_esp8266:337]: Event: Disconnected ssid='dipanwifi' bssid=
[redacted] reason='Auth Expired'
[20:15:23][W][wifi:451]: Error while connecting to network.
[20:15:23][I][wifi:193]: WiFi Connecting to 'dipanwifi'...
[20:15:25][W][wifi_esp8266:337]: Event: Disconnected ssid='dipanwifi' bssid=
[redacted] reason='Association Expired'
[20:15:25][W][wifi:451]: Error while connecting to network.
I struggled with it for some time, but eventually decided to try the other two boards I got. Both of those times, it worked flawlessly. So now I am confused. Is there something wrong with the setup, or the chip is misbehaving somehow? If anyone can shed some light, it would be much appriciated.
Thank you
Dipan
