I need to make a 8 channel 220v power strip. do these components matche together?
NodeMCU LUA V3
8 channel relay
KY-022 IR remote
the reason I chose NodeMCU LUA V3 is that it’s the cheapest mcu I found that doesn’t need soldering
I have something like this in my mind
Karosm
(Karosm)
June 1, 2025, 12:21pm
2
Yes, but you need to be careful with wiring.
This will save you some time:
Karosm:
what do you mean? because of ac electric shock?
I couldn’t find the module you suggested. the relay I posted earlier is available
since there are 13 pins in total which pins on nodemcu I should use?
IR remote and relay’s gnd and vin share pins or connect them separately?
Karosm
(Karosm)
June 1, 2025, 1:11pm
4
Actually, Esp8266 has 9 (somehow) usable gpio pins plus TX/RX.
You need them all. And some pins will trigger relays on boot. I strongly suggest to go with Esp32 board. Cost is maybe $1 more…
https://aliexpress.com/item/1005002231689053.html
if you remember I mentioned I live in Iran and I can’t buy from international websites.
my options are very limited
NodeMCU LUA V3 is 3$ and the cheapest nodemcu esp32 is 10$
with that in mind it would be best if somehow I can use NodeMCU LUA V., if it’s even possible
I know it’s not ideal but it’ll do the job?!
Karosm
(Karosm)
June 1, 2025, 3:00pm
6
Yes.
Use the same pin configuration from the link above for ESP-12F_Relay_X8
With some of the pins that have states that effect boot or change state at boot, you may be better off using 2 8266’s and only use pins that are stable at boot.
Only difference is there will be 2 devices each controlling half.
I’m literally in war zone, Tehran, and they are shuting off the Internet so I need to do configurations ASAP to be able to control the relay offline
for now I got an 4output relay
please tell me which pins are safest for relays 4 pins an which pins I should use to connect KY-022 IR remote
also please give me a esphome yaml code to control the relay with KY-022 IR remote
I know it’s a lot to ask but it’s emergency
Karosm
(Karosm)
June 17, 2025, 6:53pm
9
Gpios 4,5,12,13,14
That’s not something I can do. You need to receive and record the codes successfully from you remote control first.
these are the code I get
key #1
[15:42:12][I][remote.pronto:231]: Received Pronto: data=
[15:42:12][I][remote.pronto:233]: 0000 006D 0023 0000 003E 001D 0053 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0016 0015 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041
[15:42:12][I][remote.pronto:233]: 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0181
[15:42:12][D][remote.beo4:086]: Beo4: n_sym=68
[15:42:12][I][remote.pronto:233]: 0000 006D 0022 0000 00AE 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016
[15:42:12][I][remote.pronto:233]: 0015 0016 0016 0016 0014 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0181
[15:42:12][I][remote.samsung:061]: Received Samsung: data=0xE0E020DF, nbits=32
key #2
[15:43:52][D][remote.beo4:086]: Beo4: n_sym=70
[15:43:52][I][remote.pronto:231]: Received Pronto: data=
[15:43:52][I][remote.pronto:233]: 0000 006D 0023 0000 0023 0028 0064 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0017 0014 0016 0015 0016 0015 0041 0015 0041 0016 0040 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041
[15:43:52][I][remote.pronto:233]: 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0181
[15:43:52][D][remote.beo4:086]: Beo4: n_sym=68
[15:43:52][I][remote.pronto:233]: 0000 006D 0022 0000 00AE 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0016 0015 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0016 0015 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016
[15:43:52][I][remote.pronto:233]: 0015 0016 0015 0016 0016 0015 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0181
[15:43:52][I][remote.samsung:061]: Received Samsung: data=0xE0E0A05F, nbits=32
key #3
[15:44:28][D][remote.beo4:086]: Beo4: n_sym=70
[15:44:29][I][remote.pronto:231]: Received Pronto: data=
[15:44:29][I][remote.pronto:233]: 0000 006D 0023 0000 0035 0027 0052 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041
[15:44:29][I][remote.pronto:233]: 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0181
[15:44:29][D][remote.beo4:086]: Beo4: n_sym=68
[15:44:29][I][remote.pronto:233]: 0000 006D 0022 0000 00AE 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016
[15:44:29][I][remote.pronto:233]: 0015 0016 0016 0015 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0016 0040 0015 0041 0015 0041 0015 0041 0015 0181
[15:44:29][I][remote.samsung:061]: Received Samsung: data=0xE0E0609F, nbits=32
key #4
[15:44:56][D][remote.beo4:086]: Beo4: n_sym=68
[15:44:56][I][remote.pronto:231]: Received Pronto: data=
[15:44:56][I][remote.pronto:233]: 0000 006D 0022 0000 00AE 00AE 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0016 0015 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041
[15:44:56][I][remote.pronto:233]: 0015 0016 0015 0016 0016 0015 0015 0016 0015 0041 0015 0041 0015 0041 0016 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0181
[15:44:56][I][remote.samsung:061]: Received Samsung: data=0xE0E010EF, nbits=32
[15:44:56][I][remote.pronto:233]: 0000 006D 0022 0000 00AE 00AE 0015 0041 0015 0041 0015 0040 0016 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0016 0015 0015 0016 0015 0016 0015 0016 0015 0041
[15:44:56][I][remote.pronto:233]: 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0040 0016 0041 0015 0041 0015 0040 0016 0181
Karosm
(Karosm)
June 18, 2025, 12:50pm
11
If you use:
dump: samsung
instead of “all”, do you catch all button presses?
[16:29:36][I][remote.samsung:061]: Received Samsung: data=0xE0E020DF, nbits=32
[16:29:43][I][remote.samsung:061]: Received Samsung: data=0xE0E0A05F, nbits=32
[16:29:47][I][remote.samsung:061]: Received Samsung: data=0xE0E0609F, nbits=32
[16:29:56][I][remote.samsung:061]: Received Samsung: data=0xE0E010EF, nbits=32
code:
esphome:
friendly_name: Desk Fan
min_version: 2025.5.0
name_add_mac_suffix: false
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
password: "sha935"
wifi:
ssid: !secret wifi_ssid
captive_portal:
web_server:
remote_receiver:
pin:
number: GPIO14
inverted: true
dump: samsung
Karosm
(Karosm)
June 18, 2025, 3:11pm
13
Try with these:
binary_sensor:
- platform: remote_receiver
samsung:
data: 0xE0E020DF
nbits: 32
on_press:
then:
- switch.turn_on: relay_1
switch:
- platform: gpio
pin: GPIO4
Karosm:
Try with these:
thanks
they shut off Internet that’s why it took so long
I get this
[13:34:35][D][binary_sensor:036]: 'Remote Input1': Sending state ON
[13:34:35][D][switch:012]: 'Relay 1' Turning ON.
[13:34:35][D][binary_sensor:036]: 'Remote Input1': Sending state OFF
[13:34:35][I][remote.samsung:061]: Received Samsung: data=0xE0E020DF, nbits=32
relay doesn’t turn on/off
do I need an external 5v for the relay?
nodemcu is connected to the pc via micro usb and relay is conected to G,3v and GPIO5 pins
Uploading: harelay2.JPG…
code:
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
api:
ota:
- platform: esphome
password: "sha935"
wifi:
captive_portal:
web_server:
remote_receiver:
pin:
number: GPIO14
inverted: true
dump: samsung
binary_sensor:
samsung:
data: 0xE0E020DF
nbits: 32
on_press:
then:
switch:
- platform: gpio
pin: GPIO5
Karosm
(Karosm)
June 21, 2025, 11:13am
15
Can you send a link to that relay module. You probably have it wired incorrectly.
Karosm
(Karosm)
June 21, 2025, 5:21pm
17
Doesn’t open for me. Post an image from your link if you can’t link to something identic.
I realized few things
I can turn on /off the relay via dashboard .in1 led turns on/off but I don’t hear anything. don’t relays suppose to have a clicking sound?
it seems ir remote can turn relay off. in1 led turns off but can’t turn it back on
dashboard indicator is wrong. when it shows it’s off relay led is on and when it shows it’s on relay led is off
in product discription it says it’s active low
does it have anything to do with that? and can it be fixed?
Karosm
(Karosm)
June 22, 2025, 8:29am
19
yes, click and LED
it’s wired incorrectly and will also damage your Esp
for active LOW relay you need to add inverted: true
switch:
- platform: gpio
pin:
number: GPIO5
inverted: true
5V to JD-VCC,
not to VCC
I removed the jumper
it curently wired like this
black wire from vcc on relay to 3v on esp
green wire from gnd on relay to G on esp
blue wire from in1 on relay to D1/GPIO5 on esp
what else I should change?
I’m going to use the relay for AC. do I need to connect 5v to that jumper pin?
