NodeMcu onboard LED control
Is it possible to control the onboard LED on a nodemcu with esphome.
A quick google and its seems it should be…but im unable to get anything to work.
Infact, the LED on one o my boards constantly lashes every 60 seconds ish.
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: hidden
  password: hidden
  ap:
    ssid: "Sensor Node Bedroom"
    password: hidden
captive_portal:
logger:
# Enable Home Assistant API
api:
ota:
output:
  - platform: esp8266_pwm
    pin:
      number: D0
      inverted: true
light:
  - platform: monochromatic
    name: "Sensor Node Bedroom LED"
    output: onboard_led
binary_sensor:
  - platform: gpio
    pin: D5
    device_class: motion
  - platform: dht
    model: AM2302
    pin: D4
    temperature:
      name: "Bedroom Temperature"
    humidity:
      name: "Bedroom Humidity"
    update_interval: 60s
  - platform: adc
    pin: A0
    name: "Bedroom Brightness"
    unit_of_measurement: lux
    filters:
      - lambda: |-
          return (x / 10000.0) * 2000000.0;
  - platform: wifi_signal
    name: Sensor Node Bedroom WiFi Signal
    accuracy_decimals: 0
    unit_of_measurement: dB
    icon: mdi:wifi
    force_update: false
  - platform: uptime
    unit_of_measurement: s
    icon: mdi:timer
    force_update: false
text_sensor:
    name: Sensor Node Bedroom Uptime
    lambda: |-
      int seconds = (id(uptime_sec).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
    icon: mdi:clock-start
    update_interval: 113s
