None Degrees
Good Morning,
I have the Home Assistant Voice Preview Edition configured in my office. I have my office setup with the Everything Presence One Sensor and have it set up in my Office Area to use for temperature readings. When I ask the Home Assistant Voice to tell me the temperature in here, it says “None degrees”
Anyone have suggestions on what I am doing wrong?
Same here too. Sorry not to be of help. All I know is if I say “what is the temperature value of the room” it works.
EDIT: I’ve added this to the LLM ‘Instructions’ as a command line and it now works:
- If I ask for the temperature of a room, give the ‘temperature value’ as a response.
Ok, it works if I first speak what is the temperature value of the room, and then ask again what is the temperature of the room, but it still gives “none degrees” if I ask for another room, so the strikethrough above does not work. It’s only when I ask/speak for the temperature value beforehand. So my Instruction isn’t working. damb! I’ll keep persevering/researching…
