alias: armed_home triggers
description: ''
- platform: state
entity_id: group.door_sensors
to: 'on'
- platform: state
entity_id: group.window_sensors
to: 'on'
condition:
- condition: state
entity_id: alarm_control_panel.intrusion_alarm
state: armed_home
- service: alarm_control_panel.alarm_trigger
- service: notify.notify
message: Intrusion Alarm is triggering now
mode: single
and I have a similar automation for triggering for home_away_state.
Although I have configured a delay_time of 30 seconds in the alarm, the alarm is being triggered by these automations. How do I enable a delay for both armed_home and home_away states so that a grace period is given to enter the code to disarm?
The arming_time, delay_time, trigger_time are all between different states of the alarm_control_panel.alarm_trigger and not affect outside it. eg 60sec arming_time is just when you click the “arm_away” button it will change from disarmed to “arming” 60sec later to “armed_away”. So you create automation to use these states as triggers eg in your case you can use it to switch on/off the “armed_home_triggers” automation.
- alias: Alarm armed away mode
platform: state
to: armed_away
- service: automation.turn_on
entity_id:
- armed_home_triggers
Just a side note, groups are useful but have an inherent weakness when use as alarm.
- platform: state
to: 'on'
vs
- platform: state
entity_id:
- binary_sensor.door_1
- binary_sensor.door_2
- binary_sensor.door_3
- binary_sensor.door_4
to: 'on'
In the first example if you leave the house and forgot to close 1 door the group will remain “on” and intrusion from any other door will not trigger because it is still in the on state.
In the second example even if you left 1 door open when another door open it will trigger because that door was off to on. (hope that make sense)
Thanks for the suggestion @huu. I did not know that you could arm the panel when one of the doors or windows are open; that seems contradictory to normal alarm operations. Is there a way to stop the panel from arming when the windows or doors are open? Thanks
