I successfully installed and got HA running. Made some minor changes to the config file to ensure everything works fine. I have two Nest thermostats and proceeded to discover them, following the instructions to setup a developer account and generate the client_id and secret for my config file. After entering the OAuth PIN and restarting several more round icons appeared on the Overview. It appears that my config changes are correct but I expected to see the temp of both thermostats and the ability to change them. What am I missing?
Can you share a screen shot of your front end? You should have a climate item in the states table too. You have to click and expand the thermostat to adjust the settings.
I can get additional round icons to appear by changing the developer Nest website device permissions, but can’t get control.
click the <> state tab icon and see if you have any climate entities.
Could you please post
- Your config
- Any error log?
- Your developer account’s permission setting
homeassistant:
latitude: **.726918
longitude: ***.371438
elevation: 161
unit_system: imperial
time_zone: America/Los_Angeles
customize: !include customize.yaml
frontend:
config:
http:
discovery:
conversation:
history:
logbook:
map:
sun:
- platform: yr
tts:
- platform: google
cloud:
group: !include groups.yaml
script: !include scripts.yaml
nest:
client_id: ---****-***
client_secret: ********************
structure:
- Home
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: :3218
There are no errors in the log.
Permissions:
Thermostat: read/write
Other: Away Read, ETA Write,Structure Read/Write, Postal Code Read
You don’t need set structure
if you have only one “home” in Nest App. I am guessing you may have different name for your structure, not Home
Another possible is you must be the “owner” of your structure, a guest account cannot use Nest API.
I removed my wife’s access and now I can toggle my Home/Away status from Nest.com and it is reflected in the HA Logbook.
I expect to see an icon for each thermostat displaying their current settings and temp in Overview. Should I install HA Dashboard to see the thermostat values?
HA Dashboard is not part of home-assistant, it is unrelated.
If you click “< >” in the bottom of sidebar, you can find all of your entities, you should be able find climate.living_room
or something similar for you thermostat
If you still have problem, you can turn on debug log and see what you can get
# in configuration.yml
logger:
default: warning
logs:
homeassistant.components.climate.nest: debug
homeassistant.components.nest: debug
nest: debug
I removed the Structure and deleted the ‘Home’ structure from Nest.com. I had created a different one that have the thermostats. Now I have the Climate widgets for both thermostats but also have 20+ round icons at the top of the overview page for various features of both thermostats. How do I remove them?
More progress! I connected to my security doorbell by a different vendor.
See https://www.home-assistant.io/docs/configuration/customizing-devices/
Eventually, you may need https://www.home-assistant.io/docs/configuration/group_visibility/
Thanks! I don’t think I would have stumbled across this or the use of the developer icons without your help. I now see the value of using other yaml files, like custom.yaml. My progress is much better.
