Noob Question: Custom Configuring Homebridge File for Netatmo?
Hi!
I’m very inexperienced with this sort of thing, and I’m trying to figure out how to modify this to be functional in Home Assistant. Is that possible?
if so, what would I need to do?
This is what I attempted, uploading that folder into the “Custom_Components” in /config.
Then, in configuration.yaml, added this:
#CustomComponents
eveatmo:
extra_co2_sensor: true
co2_alert_threshold: 1000,
ttl: 540
auth:
client_id: XXX
client_secret: XXX
username: XXX
password: XXX
Then, I proceeded to utilize it as a sensor, using the Netatmo platform from HA.
When I check the configuration, I get:
Component not found: eveatmo
Platform not found: sensor.eveatmo
Thusly, I think I’m missing something obvious from that upload, or don’t have the technical knowledge to know how to activate it, if that indeed is at all possible.
Thanks for your help!
Okay, so I can get this to load in Add Ons, but I can’t get it to Install – when I click, nothing happens.
I’m wondering if it has anything to do with programming this part?
“platforms”: [
“platform”: “eveatmo”,
“name”: “eveatmo platform”,
“extra_co2_sensor”: false,
“co2_alert_threshold”: 1000,
“ttl”: 540,
“auth”: {
“client_id”: “XXXXX Create at https://dev.netatmo.com/”,
“client_secret”: “XXXXX Create at https://dev.netatmo.com/”,
“username”: “your netatmo username”,
“password”: “your netatmo password”
Any suggestions?
