Thanks for reading! I am old, but have been playing around with HA for months. Now I am getting more involved, but am having trouble with what should be a simple thing - triggering an automation with a value template. Basically I am doing this to eventually get min and max temps for day, week, month, year with date and time f the or min or max. But I wanted to start off with the minimal version
alias: daily set max temp
description: set or reset daily max temperature
- platform: time
at: "00:00:00"
value_template: >-
{{ states('input_number.max_daily_temp')|int ==
states('input_number.max_temp_reset')|int }}
value_template: >-
{{ states('sensor.gw2000b_outdoor_temperature')|float >
states('input_number.max_daily_temp')|float }}
- choose:
- conditions:
- condition: trigger
id:
- daily_reset
sequence:
- service: input_number.set_value
entity_id: input_number.max_daily_temp
value: input_number.max_temp_reset
- service: notify.alexa_media_my_show
message: hey - it is daily reset!
type: tts
- conditions:
id:
- new_max
sequence:
value: "{{ states('sensor.gw2000b_outdoor_temperature')|float }}"
message: >-
new max temp is {{states('sensor.gw2000b_outdoor_temperature')}}
degrees
type: tts
- service: input_number.increment
data: {}
entity_id: input_number.new_max_count
default:
metadata: {}
message: >-
this temperature reading of {{
states('sensor.gw2000b_outdoor_temperature')}} degrees and the
input number max daily value was
{{states('input_number.max_daily_temp')}}
type: tts
entity_id: input_number.default_action_no_new_max_count
data: {}
mode: single
Thanks for all your time and effort!
edit: the daily reset works
