Thanks for coding this integration. I’m having trouble with the integration as the “SmartHub Energy Sensor” just returns a Status of ‘unavailable’ after configuring it.
Any ideas where to start troubleshooting?
How do I force an update as I do not see anything in logs which leads me to think it’s doing nothing?
It also shows this warning message when selecting ‘settings’ from the ‘entity’ window. Not sure if that is a concern or not.
I was able to use the integration, but it never worked correct in terms of how often it collects the data. I know for sure that Coserv gives 15min intervals, I can pull the data using API. But this particular integration always pulls once a day and sometimes once if a few days, making it quite unusable.
hi! just so your message - we have worked on a few improvements, and rolled out newer versions that should’ve fixed some of the issues seen and reported by users. please give it a try and open issues on github if you find it still lacking
