I am running:
• Frigate 0.17 stable (Docker on UGREEN DXP4800 Pro NAS)
• Home Assistant latest stable (Docker container)
• Reolink cameras
The Reolink integration works perfectly (IR on/off switches are available and functional).
However, the Frigate integration is not providing working Recordings (or Record) entities. They show as “Unavailable” with the message: “This entity is no longer being provided by the frigate integration. If the entity is no longer in use, delete it in settings.”I have:
• Deleted the stale entities multiple times
• Restarted both Frigate and Home Assistant multiple times
• Reloaded the Frigate integration
• Confirmed MQTT is enabled in config.yaml (host 127.0.0.1, port 1883)
• Confirmed recording is enabled in Frigate config and live views work in the Frigate UI
The integration shows as connected, but the recording control entities never become available.
Any guidance on how to get the native Recordings switches working in Home Assistant would be greatly appreciated.
Thanks in advance!
