Not able to assign entities to area
I picked up a Govee Presence sensor (H5127CCE1) and was able to get it added to home assistant. However, there are three entities but no associated device. I can’t seem to figure out how to assign these entities to an area.
Seems like other Govee Bluetooth integrations are the same.
It seems I was impatient, they appeared after 15-30 min.
Hi, I do not have the same device to check, but did you try to disable the bottom setting of the entity?
nevermind, posted at the sam time
@Valdorik How did you get the H5127 to work/added? I’ve tried using the Govee Bluetooth integration and it always says “No devices found on the network”. I have added the Presence Sensor to the Govee Home app.
