Not able to see in the main page sonoff light tasmota firmware
HI All,
can you help me? I’m not able to see in the main page the light.
mqtt
mqtt:
broker: core-mosquitto
username: username insert into sonoff configuration
password: password insert into sonoff configuration
light:
  • platform: mqtt
    command_topic: “cmnd/sonoff-ingresso/power”
    state_topic: “stat/sonoff-ingresso/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
did you add the light to a card? Which home assistant version? Are you using lovelace? If you go to dev-tools and click on <> can you type in switch.sonoff and do you see it there?
That is not going to work!!
What’s the correct configuration? Following the steps:
  • Installed Mosquitto broker
  • filled the configuration.yaml with:
mqtt:
username: username
password: password
  • Sonoff configuration panel >> configuration MQTT
  • IP = Raspberry’s IP (fixed IP)
  • username = username_1
  • password = password_1
  • SAVE
  • filled the configuration.yaml with (below the previous insert):
    light:
    • platform: mqtt
      command-topic: “cmd/SonoffTopic/power”
      state-topic: “stat/SonoffTopic/POWER”
      qos: 1
      payload_on: “ON”
      payload_off: “OFF”
      retain: true
Final result of configuration.yaml is:
mqtt:
username: username
password: password
light:
  • platform: mqtt
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • SAVE file and restart
Not able to see in Home Assistant’s main page.
I’d like to add to a card. This is my target :slight_smile:
Hard to know when you don’t follow the instructions on how to post your code. Refer to the top of every page in the forum.
You really are better to use discovery and have it just work.
i didn’t get
What does that mean?
I didn’t understand
Follow the instructions on the tasmota wiki.
