Not all actions of an automation are executed
I’ve created an automation that gets triggered by MQTT.
I added two actions to this automation.
The value that needs to be set to the input number is calculated by a template.
The problem is that always only the first action triggers.
I don’t know if this is important but when the seconds action needs to be triggered the if condition in the first value is false.
here is my automation:
alias: Audio volume update
  description: ''
  - platform: mqtt
    topic: Audio/Status
  condition: []
  - service: input_number.set_value
      value: "{% if trigger.payload[5:-1].split(',') [0] | int  == 3 %}\n  {{ trigger.payload[5:-1].split(',')\
        \ [1] | int }}\n{% endif %}"
    entity_id: input_number.zone3_volume
      value: "{% if trigger.payload[5:-1].split(',') [0] | int  == 6 %}\n  {{ trigger.payload[5:-1].split(',')\
    entity_id: input_number.zone6_volume
  mode: single
What could be the problem here?
Check Configuration > Logs for error messages.
What do you think happens when the comparison, performed in the first template, is not equal to 3?
      value: >
          {{ trigger.payload[5:-1].split(',') [1] | int }}
        {% endif %}
The answer is that the template reports nothing and nothing is not a valid value. That explains why the second action is never performed when the first action is false as you noticed when you wrote this:
Long story short, if you create a template to supply a value, then it must supply one.
Yes that’s stupid of me, there is indeed no value when the if condition is false :roll_eyes:.
I now included the “else” part that is just putting the current (known) value of the “input_number” and it is working fine!
Thank you!
