Not all device elements work
I have a window sensor zigbee which is configured ad I can see the read out in my overview window contacts opened and closed as I seperate the contacts and moved them back in place. My problem is that my automation does not recognize once the contacts are seperated opened but it works once the window is shut or closed. That is backwards to how i wish it to operate. Not certain why the automation only half works??
If you showed your automation, we could help.
Not sure how to move it her but this is basically it
When
Door contacts opening closed
Then do
Toggle light switch light
That works fine but when I replace line 2 with
Door contacts opening open
Nothing happens upon seperating the sensors
well ok I deleted reentered it all the same and now automajically its working as I had h
