Not all of my knx sensor values are available as entity
Hello community,
I setup 40 GA in KNX with temperature and humidity values to ad them to home assistant. But not all GAs are generating an entity. some without errormessages and some with error messages.
all of them are visible with values in the groupmonitor.
my knx.yaml looks like this:
  • name: ‘KNX EG Wohnzimmer TEMPERATUR’
    state_address: “4/1/0”
    type: temperature
    state_class: measurement
  • name: ‘KNX EG Bad Waschbecken TEMPERATUR’
    state_address: “4/1/6”
    type: temperature
  • name: ‘KNX EG Küche Tür TEMPERATUR’
    state_address: “4/1/12”
    type: temperature
  • name: ‘KNX EG Vorratsraum TEMPERATUR’
    state_address: “4/1/18”
    type: temperature
  • name: ‘KNX 1. OG Kinderzimmer 1 (Frida) TEMPERATUR’
    state_address: “4/2/0”
    type: temperature
  • name: ‘KNX 1. OG Kinderzimmer 2 (Theo) TEMPERATUR’
    state_address: “4/2/6”
    type: temperature
  • name: ‘KNX 1. OG Bad Waaschbecken TEMPERATUR’
    state_address: “4/2/12”
    type: temperature
  • name: ‘KNX 1. OG Schlafzimmer Tür TEMPERATUR’
    state_address: “4/2/18”
    type: temperature
  • name: ‘KNX DG Büro 2 (Sascha) TEMPERATUR’
    state_address: “4/3/0”
    type: temperature
  • name: ‘KNX DG Büro 1 (Tanja) TEMPERATUR’
    state_address: “4/3/6”
    type: temperature
  • name: ‘KNX EG Treppenhaus TEMPERATUR’
    state_address: “0/1/0”
    type: temperature
  • name: ‘KNX EG Flur Badtür TEMPERATUR’
    state_address: “0/1/1”
    type: temperature
  • name: ‘KNX EG Eingangstür TEMPERATUR’
    state_address: “0/1/2”
    type: temperature
  • name: ‘KNX EG Küche Kochinsel Wand TEMPERATUR’
    state_address: “0/1/3”
    type: temperature
  • name: ‘KNX 1. OG Flur Badtür TEMPERATUR’
    state_address: “0/1/4”
    type: temperature
  • name: ‘KNX 1. OG Treppenhaus TEMPERATUR’
    state_address: “0/1/5”
    type: temperature
  • name: ‘KNX Schlafzimmer Balkon TEMPERATUR’
    state_address: “0/1/6”
    type: temperature
  • name: ‘KNX Schlafzimmer Bett rechts TEMPERATUR’
    state_address: “0/1/7”
    type: temperature
  • name: ‘KNX Schlafzimmer Bett links TEMPERATUR’
    state_address: “0/1/8”
    type: temperature
  • name: ‘KNX DG Büro Eingang TEMPERATUR’
    state_address: “0/1/9”
    type: temperature
  • name: ‘KNX EG Wohnzimmer Feuchte’
    state_address: “0/2/0”
    type: humidity
  • name: ‘KNX EG Vorratsraum FEUCHTE’
    state_address: “0/2/1”
    type: humidity
  • name: ‘KNX EG Treppenhaus FEUCHTE’
    state_address: “0/2/2”
    type: humidity
  • name: ‘KNX EG Küche Kochinsel Wand FEUCHTE’
    state_address: “0/2/3”
    type: humidity
  • name: ‘KNX EG Küche Tür FEUCHTE’
    state_address: “0/2/4”
    type: humidity
  • name: ‘KNX EG Eingangstür FEUCHTE’
    state_address: “0/2/5”
    type: humidity
  • name: ‘KNX EG Flur Badtür FEUCHTE’
    state_address: “0/2/6”
    type: humidity
  • name: ‘KNX EG Bad Waschbecken FEUCHTE’
    state_address: “0/2/7”
    type: humidity
  • name: ‘KNX 1. OG Bad Waschbecken FEUCHTE’
    state_address: “0/2/8”
    type: humidity
  • name: ‘KNX 1. OG Flur Badtür FEUCHTE’
    state_address: “0/2/9”
    type: humidity
  • name: ‘KNX Schlafzimmer Balkon FEUCHTE’
    state_address: “0/2/10”
    type: humidity
  • name: ‘KNX Schlafzimmer Tür FEUCHTE’
    state_address: “0/2/11”
    type: humidity
  • name: ‘KNX Schlafzimmer Bett rechts FEUCHTE’
    state_address: “0/2/12”
    type: humidity
  • name: ‘KNX Schlafzimmer Bett links FEUCHTE’
    state_address: “0/2/13”
    type: humidity
  • name: ‘KNX 1. OG Kinderzimmer 1 (Frida) FEUCHTE’
    state_address: “0/2/14”
    type: humidity
  • name: ‘KNX 1. OG Kinderzimmer 2 (Theo) FEUCHTE’
    state_address: “0/2/15”
    type: humidity
  • name: ‘KNX 1. OG Treppenhaus FEUCHTE’
    state_address: “0/2/16”
    type: humidity
  • name: ‘KNX DG Büro 2 (Sascha) FEUCHTE’
    state_address: “0/2/17”
    type: humidity
  • name: ‘KNX DG Büro Eingang FEUCHTE’
    state_address: “0/2/18”
    type: humidity
  • name: ‘KNX DG Büro 1 (Tanja) FEUCHTE’
    state_address: “0/2/19”
    type: humidity
for some values I get this error:
Logger: xknx.log
Quelle: runner.py:271
Erstmals aufgetreten: 13:30:26 (70 Vorkommnisse)
Zuletzt protokolliert: 14:30:28
Could not sync group address ‘0/2/18’ (KNX DG Büro Eingang FEUCHTE - Value)
Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/2/19
Could not sync group address ‘0/2/19’ (KNX DG Büro 1 (Tanja) FEUCHTE - Value)
Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 2/1/11
Could not sync group address ‘2/1/11’ (Unknown - Position)
For example, this genrates no error, but is not available as entity:
    type: temperature
maybe someone can help me?
HA and all integrations are up to date
warm regards
Sascha
Hi :wave:!
If it doesn’t yield any error when checking config, it will create an entity. Maybe that GA was configured with a different name before, then the new name key would be ignored.
The only other explanation would be a duplicate sensor key in configuration.yaml knx: overwriting the first before config is checked.
Hallo Farmio,
deine zweite Vermutung kann es nicht sein. Ich habe extra eine KNX.yaml erstellt um alles sauber getrennt zu halten. Mit höchster Wahrscheinlichkeit trifft deine erste Vermutung zu. Ich hatte in einem vorherigen Versuch eine Fehlkonfiguration gemacht und da die GA 0/1/0 schon verwendet.
Kann ich das irgendwie bereinigen?
LG und vielen Dank schon einmal für deine Hilfe
Sascha
Just find the entity and change its name.
Or comment the missing one out, reload, find the orphaned entity and delete it before adding it back to config.
Also please note that this forum prefers English. See https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371 (this also has some tips for formatting yaml / code in your posts).
Matthias thank you very much for your Help and for your hints :wink:
Next question will be in english.
Warm regards
Sascha
