Not every option from deconz shows up in Home Assistant
Hi all,
Quick question. I have an ID Lock 150, with a zigbee module. I paired it as a sensor in the deconz phoscon app. And in Home Assistant it shows up, and I can unlock and lock the door and see battery status.
However, within the deconz gui, I can in addition do other stuff. Like setting a pin code. like this: image
So my question is, why is this not availiable in Home Assistant? Is it simply because this is still not supported by deconz and not exposed by the API? Or did I forget to configure something?
