Not finding any Tp Link devices
Installed Home assistant core on my freenas box without any issues.
Found all my devices without issues including the roku tv.
But it doesn’t see any of the supported tp link plugs or switches.
On version 0.110.2
Any ideas?
the devices have to be in the same network as the integration uses broadcast requests for discovery, is that the case in your network?
Yes everything on the same network run by a pfsense router.
So i am guessing this is a bug in home assistant rather then any issue with freenas.?
It is very hard to say without knowing any more specifics. You could try pip install pyHS100 to install the backend library and use its pyhs100 console tool in console to its discovery is working.
The discovery is done using broadcast on port 9999/UDP, so if your firewall is blocking those that could be an issue.
