Not sure what happened - Matter and Z-Wave add-ons failed
Everything was working fine… installed the latest update to HA and when it restarted, Z-Wave and Matter reporting “Failed setup”. As a result, my Zigbee2MQTT doesn’t load anymore. Not sure why or what is actually broken. I don’t know how to diagnose this either. I struggled to get Zigbee2MQTT up and running, now it’s broken and I don’t know how to fix it - sigh.
I see this in the log
ERROR (MainThread) [homeassistant.components.mqtt.client] Failed to connect to MQTT server due to exception: [Errno -5] Name has no usable address
Did anyone else have this issue recently?
What is your install method?
Reboot host doesn’t help?
The error makes it seem like IP of mqtt server not resolved
Agreed but I don’t know why.
The add-on’s are not loading. I discovered that my Nabu trial expired so I think that might be the cause. If I try and add the repository (that is apparently not found) https://addons.home-assistant.io it is not reachable… hmmm
I don’t know what you mean by “install method”… I am using a HA Green. Rebooting did not help.
Try reconfigure addon
Other addons running I ok?
Docker or HAOS but you answer this now.
