Last night I transitioned from running a VM on a laptop to running HA bare metal on a Dell Optiplex 3070 Mini.
I used this guide: Generic x86-64 - Home Assistant (Method 1)
Here are some notes on the procedure and some very important BIOS settings.
First thing is first, I knew I would need to ensure EUFI was configured properly.
I configured the BIOS to use EUFI and turned secure boot off. (per the documentation)
Then I began the install process. Shortly into booting Ubuntu, I was giving warnings about RST being present.
I tried to run G-parted to format the NVMe (It kept wanting to boot back into Windows and exit the install and I thought a clear NVMe might fix that). That’s when I realized the NVMe wasn’t even showing up. So, back to the BIOS.
I looked all up and down the BIOS for any type of RST setting but was unable to find one. After some research I concluded that RST had something to do with an Intel specific RAID chipset. I did see a BIOS option to select RAID or AHCI so I selected AHCI rather than RAID. I rebooted and all went well after that. The rest of the install was just as described in the documentation.
I just wanted to put this note here in case anyone else out there runs into a similar issue. Be sure you’re using AHCI and not RAID.
