Noticable delay in NodeRed chain
Hello everyone!
We’ve been running HA for the last couple of months without any issue, but ran into an issue. We have two rooms, which have a button next to the door (shelly) which we want to use as kind of a bell you can ring. For this we wanted to make the lights in these rooms flash if someone was ringing.
All of that works completely fine.
Except that everything has like a 5-7 seconds delay. Pressing the button, it will take about 7 seconds for the lights to flash.
Implementing the exact same mechanism using HA Automations works without any delay, just fine.
Maybe someone has an idea on this?
Kind regards!
Some attachments:
HA running in a VirtualBox VM on a laptop (pretty powerful one, shouldn’t be an issue)
Laptop: i7-4700U - Allocated 3/4 cores to HA
8GB of RAM assigned
You should probably post this in the NodeRed section and also post your flow.
It might be some use of a node that is inapproriate for that usage.
