Automation “Low temperature”
alias: Niedrige Temperatur
description: ''
- platform: numeric_state
entity_id: sensor.netatmo_zuhause_wohnzimmer_buro_temperature
below: '17'
entity_id: sensor.netatmo_zuhause_wohnzimmer_temperature
below: '17'
entity_id: sensor.netatmo_zuhause_wohnzimmer_schlafzimmer_temperature
below: '17'
condition: []
- device_id: xxx
domain: mobile_app
type: notify
title: Niedrige Temperatur
message: '{{ trigger.to_state.state }} C im Raum {{ trigger.to_state.name }}'
mode: single
max: 10
In the server logs occurs following error:
2021-01-16 11:59:04 WARNING (MainThread) [homeassistant.components.automation.niedrige_temperatur] Niedrige Temperatur: Already running
The automation itself is working fine. I get the notifications on my smartphone. This would be more a improvement to get aride of the warning message.
What do I need to change? When I understand it right means that the automation is called multiple times at the same times and then this happen. But what I need to change so this doens’t happen?
