So I’ve been thinking a lot about notifications recently. I have a ton of automations and notifications embed within all of them… but I’m starting to wonder if calling an automation dedicated to notification is a better approach. Or if there’s an even different approach that I’m not even thinking about because I’m nowhere near an expert with home assistant…
Call a script, not an automation. You don’t need to trigger it.
I looked at doing it this way but the number of variables I would have to pass with the script call was the same as just putting the notification options in the automation. So why bother with the added complexity?
There’s a custom integration, Supernotify, that attempts to make it easier to send notifications down multiple notifier channels based on defined scenarios.
I’ve only played around with it a little, so I can’t give a full critique, but it might be something to look into before you start building out a bunch of scripts.
I took a step back and while ago and redid my notification setup.
First, I categorized the different type of notifications and defined what the notification strategy should be. I ended up with 4 categories
Emergency (smoke / co / propane detectors) - actions - all light on, emergency siren sound, announce on speakers ,emergency alerts to iPhones.
High (power failures, hvac failures, too cold, leaks) - actions - alert siren sound, announce on speakers, emergency alerts to iPhones.
Medium (devices off line, ping failures, …) - telegram message
Low (low batteries, filter replacements, …) - display in dashboard home page.
Summary - emergency = get out of bed and perhaps evacuate; high = wake me up it’s something that needs dealing with but I’m not evacuating; medium = text my phone, but don’t wake me up; low = next time I look at the dashboard is fine.
With that in place then it was just a matter of implementing.
