Hi.
When a new file appear\modified on shared folder I want to get notification with information of the file name.
I have mounted the shared folder to HA.
But the file watcher component cannot watch after files that was not edited by host.
Is there any way to do it?
The HA file and folder integrations are extremely limited. I had to use NodeRED.
I have done it via HA.
I have wrote /config/shell_command/watcher.sh
#!/bin/bash
#token for HA API stored in /config/secrets.yaml
token=$(grep 'api_token:' secrets.yaml | cut -c 12-)
files=$(find /media/movies -mmin -5 -type f ! -name ".*" | sort -n | tail -1)
curl -s -o /dev/null --show-error --fail \
-X POST -H "Authorization: Bearer $token" \
-d "{\"state\": \"$files\", \"attributes\":{\"friendly_name\":\"New file appear\"}}" \
http://localhost:8123/api/states/sensor.has_new_file
Added to configuration.yaml
shell_command:
get_latest_file: bash /config/shell_command/watcher.sh
Added to automation.yaml
- id: '1678800770219'
alias: Check newest file
description: ''
- platform: time_pattern
seconds: /30
condition: []
- service: shell_command.get_latest_file
data: {}
mode: single
- id: '1678808587026'
alias: Notify new file
description: ''
value_template: '{{states(''sensor.has_new_file'') != ''''}}'
condition: []
- service: notify.telegram_bot
message: New file - {{ states.sensor.has_new_file.state }}
parse_mode: html
mode: single
