**Home Assistant Android app version(s):** 2025.11.3-full
**Android version(s):…** 16
**Device model(s):** Pixel 7
**Home Assistant version:** core-2025.11.2
**Last working Home Assistant release (if known):**
**Description of problem, include YAML if issue is related to notifications:**
Notifications sent to phone via the companion app are duplicated.
```yaml
action: notify.mobile_app_phone
message: Hello
**Companion App Logs:**
11-18 12:56:20.760 2345 27819 D LocationSensorManager: High accuracy mode disabled, because not in zone [1_zone.home_expanded]
11-18 12:56:21.027 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:21.027 2345 27819 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:21.031 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:21.031 2345 27819 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:21.032 2345 27819 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:21.032 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:21.034 2345 27819 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:21.035 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:21.230 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:21.230 2345 14365 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:21.232 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:21.232 2345 14365 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:21.256 2345 423 I SensorReceiverBase: Sensor updates and sync completed
11-18 12:56:21.265 2345 14365 I SensorReceiverBase: Sensor updates and sync completed
11-18 12:56:24.240 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:24.241 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:24.247 2345 2345 D IntegrationRepositoryImpl: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1763492076957, currentMillis: 1763492184247)
11-18 12:56:24.265 2345 2345 D ImeBackDispatcher: switch root view (mImeCallbacks.size=0)
11-18 12:56:24.268 2345 2345 D InsetsController: hide(ime())
11-18 12:56:24.268 2345 2345 I ImeTracker: io.homeassistant.companion.android:51cc3e6e: onCancelled at PHASE_CLIENT_ALREADY_HIDDEN
11-18 12:56:24.269 2345 2345 D IntegrationRepositoryImpl: isAppLocked(): false. (LockEnabled: false, appActive: false, expireMillis: 1763492076957, currentMillis: 1763492184268)
11-18 12:56:24.270 2345 2345 D IntegrationRepositoryImpl: setAppActive(): true
11-18 12:56:28.846 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:29.356 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:29.757 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:29.780 2345 2345 D WindowOnBackDispatcher: setTopOnBackInvokedCallback (unwrapped): androidx.activity.OnBackPressedDispatcher$Api34Impl$createOnBackAnimationCallback$1@5c167be
11-18 12:56:29.859 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:33.251 2345 2345 E mpanion.android: Invalid resource ID 0x00000000.
11-18 12:56:33.306 2345 14365 D LogcatReader$readLog: Read logcat for pid 2345
11-18 12:56:33.381 2345 14365 D LogcatReader$readLog: Done reading logcat for pid 2345
11-18 12:56:33.698 2345 423 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.698 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.702 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.702 2345 423 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.703 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.703 2345 423 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.705 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.706 2345 423 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.706 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.707 2345 423 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.709 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.709 2345 25178 D ServerConnectionInfo: Using internal URL
11-18 12:56:33.711 2345 423 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.711 2345 423 D ServerConnectionInfo: Using internal URL
11-18 12:56:33.711 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.713 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.714 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.714 2345 423 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.716 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.717 2345 423 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.717 2345 25178 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.718 2345 423 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.719 2345 25178 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.719 2345 25178 D ServerConnectionInfo: Using internal URL
11-18 12:56:33.720 2345 25178 D WebSocketCoreImpl$sendMessage: Sending message 3308: {type=ping, id=3308}
11-18 12:56:33.720 2345 25178 D WebSocketCoreImpl$sendMessage: Message number 3308 sent awaiting answer from WebSocket
11-18 12:56:33.720 2345 423 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.721 2345 423 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:33.723 2345 423 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:33.723 2345 423 D ServerConnectionInfo: Using internal URL
11-18 12:56:33.724 2345 423 D WebSocketCoreImpl$sendMessage: Sending message 3309: {type=ping, id=3309}
11-18 12:56:33.725 2345 423 D WebSocketCoreImpl$sendMessage: Message number 3309 sent awaiting answer from WebSocket
11-18 12:56:33.737 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:56:33.740 2345 2541 D WebSocketCoreImpl: Message id 3308 received
11-18 12:56:33.740 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:56:33.741 2345 2541 D WebSocketCoreImpl: Message id 3309 received
11-18 12:56:42.341 2345 2345 D LocationSensorManager: Received location update.
11-18 12:56:42.347 2345 2345 D ForegroundServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
11-18 12:56:42.347 2345 25178 D LocationSensorManager: Last Location:
11-18 12:56:42.347 2345 25178 D LocationSensorManager: Coords:(38.6732257, -90.3288059)
11-18 12:56:42.347 2345 25178 D LocationSensorManager: Accuracy: 100.0
11-18 12:56:42.347 2345 25178 D LocationSensorManager: Bearing: 0.0
11-18 12:56:42.348 2345 25178 D LocationSensorManager: Begin evaluating if location update should be skipped
11-18 12:56:42.348 2345 25178 D LocationSensorManager: Received location that is 54 milliseconds old, 1763492202294 compared to 1763492202348 with source fused
11-18 12:56:42.348 2345 25178 D LocationSensorManager: Duplicate location received, not sending to HA
11-18 12:56:51.053 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:56:51.066 2345 2541 D WebSocketCoreImpl: Message id 2075 received
11-18 12:56:51.084 2345 14365 D WebSocketCoreImpl$sendMessage: Sending message 3310: {type=mobile_app/push_notification_confirm, webhook_id=899e0cde7f88e2d8a6c9b7c41bf66fca5873296b49081e70f3143396d09e4ff6, confirm_id=58b5e2e53fa5396afbc91f25898d51bb, id=3310}
11-18 12:56:51.085 2345 14365 D WebSocketCoreImpl$sendMessage: Message number 3310 sent awaiting answer from WebSocket
11-18 12:56:51.086 2345 25178 D WebSocketCoreImpl$sendMessage: Sending message 3311: {type=mobile_app/push_notification_confirm, webhook_id=899e0cde7f88e2d8a6c9b7c41bf66fca5873296b49081e70f3143396d09e4ff6, confirm_id=58b5e2e53fa5396afbc91f25898d51bb, id=3311}
11-18 12:56:51.087 2345 25178 D WebSocketCoreImpl$sendMessage: Message number 3311 sent awaiting answer from WebSocket
11-18 12:56:51.090 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:56:51.092 2345 2541 D WebSocketCoreImpl: Message id 3310 received
11-18 12:56:51.093 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:56:51.094 2345 2541 D WebSocketCoreImpl: Message id 3311 received
11-18 12:56:51.104 2345 2345 D MessagingManager$handleMessage: Creating notification with following data: {message=Hello, webhook_id=899e0cde7f88e2d8a6c9b7c41bf66fca5873296b49081e70f3143396d09e4ff6, server_id=1}
11-18 12:56:51.118 2345 2345 D MessagingManager: Show notification with tag "null" and id "-1739347562"
11-18 12:56:51.120 2345 2345 D MessagingManager$handleMessage: Creating notification with following data: {message=Hello, webhook_id=899e0cde7f88e2d8a6c9b7c41bf66fca5873296b49081e70f3143396d09e4ff6, server_id=1}
11-18 12:56:51.125 2345 2345 D MessagingManager: Show notification with tag "null" and id "-1739347559"
11-18 12:56:54.258 2345 2345 D NotificationManagerExtensionsKt: Cancel notification with tag "null" and id "0"
11-18 12:56:54.259 2345 2345 D NotificationManagerExtensionsKt: Check if the notification is in a group...
11-18 12:56:54.259 2345 2345 D NotificationManagerExtensionsKt: Notification is not in a group. Cancel notification...
11-18 12:56:54.277 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:56:54.282 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:56:56.002 2345 30471 D LogcatReader$readLog: Read logcat for pid 2345
11-18 12:56:56.022 2345 14365 D NotificationDeleteReceiver$onReceive: Notification cleared event successful!
11-18 12:56:56.064 2345 30471 D LogcatReader$readLog: Done reading logcat for pid 2345
11-18 12:56:56.101 2345 2386 I mpanion.android: Waiting for a blocking GC ProfileSaver
11-18 12:56:56.133 2345 2386 I mpanion.android: WaitForGcToComplete blocked ProfileSaver on Background for 31.370ms
11-18 12:57:00.023 2345 2345 D SensorReceiverBase: Received intent: android.intent.action.TIME_TICK
11-18 12:57:00.025 2345 30471 D LastUpdateManager: Last update is android.intent.action.TIME_TICK
11-18 12:57:00.029 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:00.032 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:00.033 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:00.034 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:00.034 2345 26413 D ServerConnectionInfo: Using internal URL
11-18 12:57:00.039 2345 26413 D ActivitySensorManager: Unregistering for activity updates.
11-18 12:57:00.041 2345 26413 D ActivitySensorManager: Registering for activity updates.
11-18 12:57:00.106 2345 14365 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:00.108 2345 14365 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:00.151 2345 30471 D ForegroundServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
11-18 12:57:00.626 2345 30471 D ActivitySensorManager: Received activity update.
11-18 12:57:03.733 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.733 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.737 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.738 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.743 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.743 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.744 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.745 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.746 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.747 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.747 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.747 2345 26413 D ServerConnectionInfo: Using internal URL
11-18 12:57:03.748 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.748 2345 30471 D ServerConnectionInfo: Using internal URL
11-18 12:57:03.748 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.749 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.751 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.751 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.751 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.751 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.753 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.753 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.753 2345 26413 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.753 2345 30471 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:03.754 2345 26413 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.754 2345 26413 D ServerConnectionInfo: Using internal URL
11-18 12:57:03.756 2345 30471 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:03.756 2345 30471 D ServerConnectionInfo: Using internal URL
11-18 12:57:03.756 2345 26413 D WebSocketCoreImpl$sendMessage: Sending message 3312: {type=ping, id=3312}
11-18 12:57:03.762 2345 26413 D WebSocketCoreImpl$sendMessage: Message number 3312 sent awaiting answer from WebSocket
11-18 12:57:03.763 2345 30471 D WebSocketCoreImpl$sendMessage: Sending message 3313: {type=ping, id=3313}
11-18 12:57:03.763 2345 30471 D WebSocketCoreImpl$sendMessage: Message number 3313 sent awaiting answer from WebSocket
11-18 12:57:03.779 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:57:03.780 2345 2541 D WebSocketCoreImpl: Message id 3312 received
11-18 12:57:03.782 2345 2541 D WebSocketCoreImpl: Websocket: onMessage (text)
11-18 12:57:03.782 2345 2541 D WebSocketCoreImpl: Message id 3313 received
11-18 12:57:05.153 2345 2345 D NotificationManagerExtensionsKt: Cancel notification with tag "null" and id "0"
11-18 12:57:05.154 2345 2345 D NotificationManagerExtensionsKt: Check if the notification is in a group...
11-18 12:57:05.154 2345 2345 D NotificationManagerExtensionsKt: Notification is not in a group. Cancel notification...
11-18 12:57:05.195 2345 14365 D ServerConnectionInfo: usesVpn is: false
11-18 12:57:05.199 2345 14365 D ServerConnectionInfo: usesInternalSsid is: true, usesWifi is: true
11-18 12:57:05.242 2345 14365 D NotificationDeleteReceiver$onReceive: Notification cleared event successful!
11-18 12:57:05.673 2345 2345 D ImeBackDispatcher: switch root view (mImeCallbacks.size=0)
11-18 12:57:05.705 2345 2345 D InsetsController: hide(ime())
11-18 12:57:05.707 2345 2345 I ImeTracker: io.homeassistant.companion.android:18056f4a: onCancelled at PHASE_CLIENT_ALREADY_HIDDEN
11-18 12:57:05.709 2345 2345 D IntegrationRepositoryImpl: isAppLocked(): false. (LockEnabled: false, appActive: true, expireMillis: 1763492076957, currentMillis: 1763492225708)
11-18 12:57:05.730 2345 2345 D IntegrationRepositoryImpl: setAppActive(): true
11-18 12:57:06.227 2345 26347 D LogcatReader$readLog: Read logcat for pid 2345
**Screenshot or video of problem:**
**Additional information:**
