I’m sorry if this is a bit basic, but I really have tried hard (and failed) to find an answer in the docs and by searching the forum.
I want to send an SMS message via my Huawei 5G router which is just the current value of an input_select helper variable. I can easily send a text message, that works fine but I cannot work out the correct syntax to be the value of an input_select helper variable.
Using the developer tools services thing, the notify works fine with static text, e.g.
