Notify.html5 / pywebpush broken due to openssl 1.1
it seem pywebpush which is used by notify.html5 component no longer works if:
  1. openssl 1.1
  2. pyelliptic 1.5.7+
furthermore, pyelliptic is deprecated and no longer supported.
they did a “fix” for openssl 1.1 by removing ECC support (needed by pywebpush) in the last 1.5.8
my current hack is to keep 1.5.7 and hardcode the path by compatible openssl 1.0 lib.
i changed in ~/hass/deps/pyelliptic/openssl.py:
#libname = ctypes.util.find_library(‘crypto’)
libname = “/usr/lib/libcrypto.so.1.0.0”
Not a long term solution though.
Anyone else have any good ideas?
Edit:
this will probably be fixed in pywebpush according to
https://github.com/web-push-libs/pywebpush/issues/49
