Hi
i have this gateway for my Velux, when the gateway is offline and i restart HA… HA fails to complete the setup… i can see that on the notifications page in HA itself… there is an notification there
is it possible to make an automation for failed components, so i will also have a PUSH message on the HA android app with the notify service ? how to trigger this?
If you get a persistent notification in HA about the failed component, you can trigger on that event.
- alias: persistent_notification_create
mode: parallel
- platform: event
event_type: call_service
event_data:
domain: persistent_notification
service: create
condition:
- condition: template
value_template: >
{{ trigger.event.data.service_data.notification_id and
trigger.event.data.service_data.notification_id[:5] == "myha_" }}
You need to find/filter out the event data for the failed notification in the condition.
hey
happened again, how can i change your automation?
this is wat i saw in the developer states page:
entity : persistent_notification.invalid_config
state : notifying
attributes:
title: Invalid config
message: The following integrations and platforms could not be set up:
- [velux](https://www.home-assistant.io/integrations/velux)
Please check your config.
and below error from log file
2020-08-04 16:40:57 WARNING (MainThread) [pyvlx] Connecting to KLF 200.
2020-08-04 16:40:58 ERROR (MainThread) [homeassistant.setup] Error during setup of component velux
File "/usr/src/homeassistant/homeassistant/setup.py", line 193, in _async_setup_component
result = await asyncio.wait_for(task, SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 483, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/velux/__init__.py", line 31, in async_setup
await hass.data[DATA_VELUX].async_start()
File "/usr/src/homeassistant/homeassistant/components/velux/__init__.py", line 69, in async_start
await self.pyvlx.load_scenes()
File "/usr/local/lib/python3.8/site-packages/pyvlx/pyvlx.py", line 89, in load_scenes
await self.scenes.load()
File "/usr/local/lib/python3.8/site-packages/pyvlx/scenes.py", line 51, in load
await get_scene_list.do_api_call()
File "/usr/local/lib/python3.8/site-packages/pyvlx/api_event.py", line 21, in do_api_call
await self.send_frame()
File "/usr/local/lib/python3.8/site-packages/pyvlx/api_event.py", line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File "/usr/local/lib/python3.8/site-packages/pyvlx/pyvlx.py", line 72, in send_frame
await self.connect()
File "/usr/local/lib/python3.8/site-packages/pyvlx/pyvlx.py", line 45, in connect
await self.connection.connect()
File "/usr/local/lib/python3.8/site-packages/pyvlx/connection.py", line 85, in connect
self.transport, _ = await self.loop.create_connection(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1050, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1080, in _create_connection_transport
await waiter
ConnectionAbortedError: SSL handshake is taking longer than 60.0 seconds: aborting the connection
mode: parallel
- platform: event
event_data:
service: create
condition:
value_template: >
{{ trigger.event.data.service_data.title == "Invalid config" }}
should do it.
