Hi i am trying to make an automation which triggers if the garage door is left open. I can’t use the proximity of persons because not everybody carries his/her phone all the time. I want to receive a notification when the door is left open for 5 minutes and after that every X minutes a reminder that it still is open… At the moment i’m thinking of making a time based automation which checks the state every X minutes and when it is still open it sends the notification. But… this feels as “polling” and the automation is invoked way to often. Is there a smarter way to do this?
Try this
alias: Garage Door Left Open Reminder
- platform: state
entity_id: binary_sensor.garage_door
to: "on"
for: "00:05:00" # Wait 5 minutes before triggering
- service: notify.mobile_app_mobil
message: "Garage door is still open!"
- repeat:
while:
- condition: state
state: "on"
sequence:
- delay: "00:10:00" # Change to X minutes for reminders
- service: notify.mobile_app_rmobil
message: "Reminder: The garage door is still open!"
mode: restart
Thanks, perfect. i made a small change because waiting 10 minutes before sending the notification after the condition has been met is to late. The door could have been shut by this time.
My order is:
- notify
- repeat until closed
- wait X (or Y)
- notify again
Wouldn’t it be better to trigger on time- every five minutes- then test the sensor status in condition?
Is a timer-based-triggertm better then a delay()tm ?
There is no “better”. It depends on what you want to happen.
The state trigger only triggers when the entity state changes. When the door state changes to open for five minutes you will trigger the automation. It will never trigger again until the state changes to closed then to open again. In other words, once. And only once.
The time trigger will trigger periodically, like every five minutes. The automation can then check the state condition. If the door is open, trigger the automation. In other words, as long as the door is open you will get repeated messages until it is closed.
Using delays, especially longer ones, aren’t robust against HA restarts. Use timers instead which are restored upon a restart.
Also have a look at the built-in alert integration.
There’s also this powerful custom integration.
