I had my Home Assistant system running smoothly for quite a while. But last week my NSPanel stopped, the time display was frozen and no input was possible. The hardware buttons and also the relay switching from the dashboard worked. So I think something in the update process broke. In the MQTT logs I see this:
tele/tasmota_nspanel1/RESULT {"CustomRecv":"event,startup,53,eu"}
And no response is sent from my RasPi with its HomeAssistant installation. I have to admizt that I was a little bit confused when I set up the NSPanel with the eco-system, so I thought an update is always a good idea
But now I’m stuck, the ESP-firmwar update stuck with a SAFEBOOT, maybe somebody can give me a hint how to correctly flash the lastes FW:
SAFEBOOT
NSPanel
NSPanel_WZ
Program Version 13.1.0(safeboot)
Build Date & Time 2023-08-15T07:58:37
Core/SDK Version 2_0_11/4.4.5.230722
Uptime 0T00:12:53
Flash Write Count 1314
Boot Count 119
Restart Reason Software reset CPU
Friendly Name 1 NSPanel_WZ
Friendly Name 2 NSPanel1_WZ
AP1 SSId (RSSI) oxxxxxx 8 (100%, -47 dBm) 11n
Hostname tasmota-nspanel1-2268
IPv6 Global (wifi) 2a01:aea0:dd3:xxxxxx
IPv6 Local (wifi) fe80::8264:xxxxxxxxxx
MAC Address 80:64:6F:xxxxxxxx
IP Address (wifi) 192.168.xxxxx
Gateway 192.168.xxxxxx
Subnet Mask 255.255.255.0
DNS Server1 192.168.xxxxxxxxxxxxxx
DNS Server2 2a01:aea0:dd3:xxxxxxxxxxxxx
HTTP API Enabled
MQTT Host 192.168.xxxxxxxxxx
MQTT Port 1883
MQTT TLS Disabled
MQTT User mqtt
MQTT Client DVES_C388DC
MQTT Topic tasmota_nspanel1
MQTT Group Topic 1 cmnd/tasmotas/
MQTT Full Topic cmnd/tasmota_nspanel1/
MQTT Fallback Topic cmnd/DVES_C388DC_fb/
MQTT No Retain Disabled
ESP Chip Id 12814556 (ESP32-D0WD-V3 rev.3)
Flash Chip Id 0x16405E (DIO)
Flash Size 4096 KB
Program Flash Size 4096 KB
Program Size 801 KB
Free Program Space 30 KB
Free Memory 145.7 KB (frag. 25%)
Partition safeboot* 832 KB (used 96%)
Partition app0 2880 KB
Partition fs 320 KB
Tasmota 13.1.0 by Theo Arends
