I was fascinated by NSPanel from Sonoff and the idea to have 2 buttons and a mini display to show some information. Lighter than a tablet (with update/maintenance). The idea was perfect.
At the end, each update is a total nightmare. between 3 to 7 days, my 3 panels doesn’t work and show what any IT people is afraid : the bluescreen and the nspanel who loop busy to reboot …
I follow Blackymas blueprint setup and I try all options that it seems correct.
Btw, it can work easily (4.3.39 to 4.3.42) but after don’t (4.3.42 to 202510.0)
I have no logical explanation
I proceed to
- reimport blueprint
- copy nspanel_us.tft and nspanel_blank.tft in home assistant.
- I update the module
- clean all
- install one by one
and now the nightmare begin because nothing is logical. Some device can work as a charm immediately (let’s say a couple of hours…) and other don’t
the diagnostic card show this
Nextion display: Connected Version Blueprint: 202510.0 Version ESPHome: 202510.0 Version TFT: Unknown
the yaml is
api:
encryption:
key: "Yeahthereisakey"
substitutions:
###### CHANGE ME START ######
device_name: "nschparents"
wifi_ssid: !secret wifi_ssid
wifi_password: !secret wifi_password
nextion_update_url: "https://w.x.y.z:8123/local/nspanel_us.tft"
##nextion_update_url: "https://homeassistant.local:8123/local/nspanel_us.tft"
nextion_blank_url: "https://w.x.y.z:8123/local/nspanel_blank.tft"
##### addon-configuration #####
## addon_climate ##
# addon_climate_heater_relay: "1" # possible values: 1/2
##### CHANGE ME END #####
packages:
remote_package:
url: https://github.com/Blackymas/NSPanel_HA_Blueprint
ref: main
files:
- nspanel_esphome.yaml # Core package
# - advanced/esphome/nspanel_esphome_advanced.yaml # activate advanced (legacy) elements - can be useful for troubleshooting
# - nspanel_esphome_addon_climate_cool.yaml # activate for local climate (cooling) control
# - nspanel_esphome_addon_climate_heat.yaml # activate for local climate (heater) control
refresh: 300s
logger:
level: DEBUG
esp32:
framework:
type: esp-idf
##### My customization - Start #####
wifi:
manual_ip:
# Set this to the IP of the ESP
static_ip: w.x.y.z.
# Set this to the IP address of the router. Often ends with .1
gateway: w.x.y.a
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
dns1: 1.1.1.2
dns2: 1.0.0.2
##### My customization - End #####
Homeassistant is HAOS debian image virtualized with KVM through OpenMediaVault
I can ping and reach the nspanel, home assistant. I can do name resolution. All seems correct
But
If I choose TFT display “NS Panel US” for me, It wil ltry to download the tft from github
log
[15:41:24.203][D][switch:020]: ‘Nextion display - Power’ Turning ON.
[15:41:24.207][D][switch:063]: ‘Nextion display - Power’: Sending state ON
[15:41:24.414][D][nspanel.addon.upload_tft:121]: Starting TFT upload…
[15:41:24.419][D][nextion.upload.idf:154]: TFT upload requested
[15:41:24.426][D][nextion.upload.idf:155]: Exit reparse: YES
[15:41:24.427][D][nextion.upload.idf:156]: URL: https://raw.githubusercontent.com/Blackymas/NSPanel_HA_Blueprint/v202510.0/hmi/nspanel_us.tft
[15:41:24.432][D][nextion.upload.idf:171]: Exit reparse mode
[15:41:24.443][D][nextion.upload.idf:185]: Baud rate: 115200
[15:41:25.172][D][nextion.upload.idf:232]: TFT size: 7622920 bytes
[15:41:25.173][D][nextion.upload.idf:245]: Uploading
[15:41:30.681][D][nextion.upload.idf:282]: Upload resp: 0 B
[15:41:30.682][E][nextion.upload.idf:290]: Upload prep failed 0 ‘’
[15:41:30.686][D][nextion.upload.idf:291]: Close HTTP
[15:41:30.699][E][nextion.upload:020]: Upload failed
[15:41:30.700][W][component:453]: script took a long time for an operation (6289 ms)
[15:41:30.709][W][component:456]: Components should block for at most 30 ms
[15:41:30.786][W][component:453]: api took a long time for an operation (6303 ms)
[15:41:30.786][W][component:456]: Components should block for at most 30 ms
[15:41:30.786][D][nspanel.addon.upload_tft:305]: Attempt #1 at 115200 bps returned: FAILED
[15:41:30.786][I][addon_upload_tft.script.upload_tft_attempt:306]: Restarting ESPHome
Ok, let’s try locally, I choose “nextion_update_url”. Btw, I can use the URL and download immediately the tft file from my desktop but I remove Firewall/Internet/DNS stuff.
[15:44:48.430][D][main:295]: Attempting to upload TFT
[15:44:48.436][D][nspanel.addon.upload_tft:296]: Attempt #1 at 115200 bps
[15:44:48.706][W][nextion:091]: Not connected
[15:44:49.212][W][nextion:091]: Not connected
[15:44:49.446][D][nspanel.addon.upload_tft:114]: Waiting for empty UART and Nextion queues
[15:44:49.726][W][nextion:091]: Not connected
[15:44:50.109][D][switch:020]: ‘Nextion display - Power’ Turning ON.
[15:44:50.109][D][switch:063]: ‘Nextion display - Power’: Sending state ON
[15:44:50.261][W][nextion:091]: Not connected
[15:44:50.757][W][nextion:091]: Not connected
[15:44:51.303][W][nextion:091]: Not connected
[15:44:51.468][D][nspanel.addon.upload_tft:121]: Starting TFT upload…
[15:44:51.472][D][nextion.upload.idf:154]: TFT upload requested
[15:44:51.473][D][nextion.upload.idf:155]: Exit reparse: YES
[15:44:51.473][D][nextion.upload.idf:156]: URL: https://w.x.y.z:8123/local/nspanel_us.tft
[15:44:51.477][D][nextion.upload.idf:171]: Exit reparse mode
[15:44:51.477][D][nextion.upload.idf:185]: Baud rate: 115200
[15:44:52.668][D][nextion.upload.idf:232]: TFT size: 7622920 bytes
[15:44:52.669][D][nextion.upload.idf:245]: Uploading
[15:44:58.172][D][nextion.upload.idf:282]: Upload resp: 0 B
[15:44:58.179][E][nextion.upload.idf:290]: Upload prep failed 0 ‘’
[15:44:58.180][D][nextion.upload.idf:291]: Close HTTP
[15:44:58.197][E][nextion.upload:020]: Upload failed
[15:44:58.197][W][component:453]: script took a long time for an operation (6742 ms)
[15:44:58.197][W][component:456]: Components should block for at most 30 ms
[15:44:58.209][W][component:453]: api took a long time for an operation (6751 ms)
[15:44:58.233][W][component:456]: Components should block for at most 30 ms
[15:44:58.233][D][nspanel.addon.upload_tft:305]: Attempt #1 at 115200 bps returned: FAILED
[15:44:58.233][I][addon_upload_tft.script.upload_tft_attempt:306]: Restarting ESPHome
[15:44:58.234][I][app:219]: Rebooting safely
[15:44:58.249][D][esp32.preferences:149]: Writing 2 items: 1 cached, 1 written, 0 failed
INFO Processing expected disconnect from ESPHome API for nschparents @ 192.168.68.31
WARNING Disconnected from API
To resume:
- no logical explanation
- log aren’t very verbose even in debug
- no clue
- update break without reason
Any idea before I smack it with my best hammer?
Thanks in advance if you read and specially if you have an idea
