ntfy Core Integration can be found here
Currently, the ntfy Core Integration (Added in 05.2025) only supports sending text notifications to a ntfy server. Ntfy itself supports sending message as markdown with images (docs ). There is a HACS project (github[dot]com/hbrennhaeuser/homeassistant_integration_ntfy) for ntfy that already seems to support image notifications, but I feel being able to send images with the core integration is important as I use ntfy for all my notifications, and I have a frigate security system integrated into Home Assistant I would like image notifications for.
If any further details or information is needed feel free to contact me here or comment.
Cheers, Liftoff1862
tr4nt0r
(tr4nt0r)
June 22, 2025, 6:22pm
2
I submitted a PR that is currently waiting for approval that will allow attaching files and images (via URL). Attachment upload and actions will come later.
dev β tr4nt0r:ntfy_send_message
opened 10:29AM - 24 Apr 25 UTC
## Proposed change
Adds an action `ntfy.publish` that allows using addition⦠al functionality of the ntfy service. Currently it supports all functions except action buttons and file upload
## Type of change
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/38725
- Link to developer documentation pull request:
- Link to frontend pull request:
## Checklist
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
Are message templates supported?
Jishin
(Jishin)
August 23, 2025, 7:12pm
4
Amazing, thank you, canβt wait for it to be merged!
