NUC Install - Directory HomeAssistant not found
I try to found the HomeAssistant folder on my Hassio install.
I have install the SSH Terminal and when I search in srv folder I found nothing.
Somebody know how I can find the HomeAssistant folder ?
System Health
Home Assistant Core Integration
version: 0.118.2
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.6
os_name: Linux
os_version: 5.4.77
arch: x86_64
timezone: UTC
Home Assistant Cloud
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
Hass.io
host_os: HassOS 4.17
update_channel: stable
supervisor_version: 2020.11.0
docker_version: 19.03.12
disk_total: 109.3 GB
disk_used: 9.4 GB
healthy: true
supported: true
board: intel-nuc
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.3.0), deCONZ (6.5.0), File editor (5.2.0), ESPHome (1.15.3), Let's Encrypt (4.11.0), Mosquitto broker (5.1), OpenZWave (0.7.0), Terminal & SSH (8.9.1)
Lovelace
dashboards: 1
mode: storage
resources: 0
You mean the config folder? Should be in /config or /root/config. There’s other stuff in /root as well like addons and backups :slight_smile:
Thx, but I find the “solution” with new OZW we don’t have directory to put custom config :frowning:
They works on it but now not available
thx
